Airstriker
Quote from: gravityblock on January 16, 2010, 04:28:57 PM
Let's work together instead of against each other.  We will get more done this way.
Done. I was always for that but simply putting magic to the concept will not make it work. Let's stick to the facts and physics only. Ok?
I think most of it we have cracked. Now we need experiments only.
JLN has a new video:
http://jnaudin.free.fr/steorn/indexen.htm
Looks very well.  However, do you know anything about the power input ? Current | voltage ? Does anybody here have a direct contact with him? Would be nice if he could test different toroid orientation (the one I've shown) and compare the input power. His setup is very precise so it should give a good comparison.
gyulasun
Wonder how Naudin connected the compensation coils and also the variable power resistor?
Probably the compensation coils works against the main flux in each toroidal core?
Dissipation in the power resistor is negligible with respect to the gain with flat pulses?
Gyula
teslaalset
@All,
Are you guys in for a discussion on how a Solid State Orbo should be implemented?
Maybe we should open a dedicated thread on this.
[edit] Never mind, there is already one. Found it. Sorry!
PaulLowrance
I just got my mini 1" OD orbo to run using the magamp metglas core. For now the toroid is not mounted, so I have to hold it, lol. It's very sensitive. For some reason it will only run if the toroid is slightly slanted, at least so far. If Sean is reading these posts, he may split a gut laughing at my hand held toroid orbo. How's that for precision?  ;D
Anyhow, it's pretty cool seeing this run on only 37 turns. Right now it seems very inefficient, so we still might have a ways to go before figuring out the Steorn Orbo secrets. I did not measure the input power or even the voltage, yet, but according to the meter it was drawing ~ 200mA DC.
Bruce_TPU
Quote from: gyulasun on January 16, 2010, 02:37:02 PM
HI FOLKS,
As someone already pointed out,  the measured nearly 1H inductance by Steorn includes the four toroidal coils in series.
If this is really so, then the 1H should be divided by 4 if four coils are in series,  so this gives around 240-250mH for any one toroidal coil.
rgds, Gyula
Hi Paul,
Your thoughts on the above post, please...
Thanks,
Bruce
