0 Members and 42 Guests are viewing this topic.
Airstriker
Quote from: teslaalset on January 18, 2010, 08:05:30 AM
@PaulLawrence:
Impressive analysis Paul. Thanks for sharing.
In your enthusiasm you might have overlooked the option I proposed earlier to recycle the current that is stored in the coil.
If you mount a (fast) diode in parallel to the coil you re-use another wasted energy source.
The coil holds P=0.5*L*I^2 W. The diode will push that energy to the coil after switching off.
In this way you can switch off earlier in time and thus use less power resulting in same mechanical output.
What your view on this?
As I've said earlier, I don't think there is much sense in the recycle circuit, as the metglas material has very high remanence value (about 0.5 T) comparing to BSAT which is 0.57T.
PaulLowrance
Quote from: Airstriker on January 18, 2010, 08:55:37 AM
No so in the Orbo. That's only if a square loop core is going to be flipped. If it does not go near the flipping point, then it's rather linear, and you get nearly all of the energy back. In my 37 turn metglas core, the inductance is 35 *micro* henry to at least 4 amps and probably far high levels of current. Although if the current is taken to a certain point, then the core flips, and then you have massive inductance.  :)
btw, the field on the metglas from the NdFeB is no were near 0.5T. In fact, if you do a FEMM analysis you'll see it's far far lower. Furthremore, the *effective* permeability on the metglas core in an *open* magnetic loop (in the case of the NdFeB magnet) is extremely low, far below 20.
Bruce_TPU
Hi Paul,
So you would still recomend 37 turns on our new cores?  Did you use 20 awg wire for your turns?
Thanks and great job!
Bruce
teslaalset
Quote from: PaulLowrance on January 18, 2010, 08:52:19 AM
Well Sean & Steorn shot down TK's & everyone elses voltage & current scope photos, except mine so far. TK's scope photos are nothing like Steorns in terms of the RL rise times, as Steorn's is a square wave. So it looks like the metglas cores are the hot ticket.
Good luck on your replications boys & girls.  ;D
Paul, can you mention once more what exact metglas core we need to order?
Thanks,
Bruce_TPU
Hello ALL,
Build video #3, as everything starts to take shape...  ;)
http://www.youtube.com/watch?v=a85zP0IiW8M
Quote from: teslaalset on January 18, 2010, 10:18:36 AM
Thanks,
Not to answer for Paul, but it was the MP2510P4AS
http://www.metglas.com/products/page5_1_6_4_1_b.asp
