0 Members and 40 Guests are viewing this topic.
woopy
Hi all
this mornimg i open the door of my lab with no hope of something special.
I left my OSSBO replication yesterday at 24.00 spining             at 214 rpm with battery (AAA) voltage at 1.28  volts accus (NIMH 3000ma) in serie (completely depleted) at 130 mv.  the Multimeter and scope turned off so no eventual voltage interaction
So i open the door and guess what         the OSSBO is still spinning         at 223 rpm the AAA voltage is 1.24 volt and the depleted Nimh accu is now at (average) 145 mv  ???????????
what is special is that the voltage in the accu is not regular and varies quickly up and down from 140 to 155-160 mv ??
Very interesting  BRAVO and thanks to OSSIE for sharing.     What about your experiment ?
I have now to go for the day so i will leave the OSSBO running and i will see what happens this evening.
regards
Laurent
captainpecan
Quote from: woopy on January 27, 2010, 03:26:13 AM
Great work!  Keep us updated.  As far as your depleted batteries acting funny, it seems they are most likely just not holding their charge.  They may need reconditioned, but I'm not sure this setup is the most ideal to do that like a true bedini could.  You may want to try different batteries, or simply just remove those and just run off the AAA for now and see if you can build it back up to where it started, or at least to get it to stay where it is at.  It's possible that you may have gained a small amount of energy while you let it run but can't tell because your overly depleted batteries are wasting it.  Just a thought.
gravityblock
Quote from: exnihiloest on January 27, 2010, 03:06:41 AM
Misinformation. Since general relativity, we know the effects of gravity as indistinguishable from the effects of acceleration, so any accelerometers are gravimeters.
http://en.wikipedia.org/wiki/Gravimeter
It's measuring the effects of acceleration due to gravity.  It is not measuring gravity directly, it is measuring gravity indirectly through the effects of acceleration.  Look at my statement again,  "...Gravity is a weak force that has no instruments to measure it directly...", and you will see I said directly.
When an object is not accelerating in a gravitational field such as resting on the surface of a planet, then according to the accelerometers there is no gravity, but we know this is not a correct measurement because it can only measure the effects of gravity due to acceleration.  There are also other methods to measure gravity indirectly.
My statement was not misinformation.  My statement was misunderstood and taken out of context by poor reading comprehension, as we have seen many times in this thread already.  It's no big deal, sometimes my reading comprehension isn't good either.  My writing skills are much worst.  My posts are long enough, and I try to keep them as short as possible so they are read.....but this leads to leaving words out or speaking in general and this could cause it to be misread.
The Aharonovâ€"Bohm effect can be measured indirectly by its effects also.  Without the effects it is extremely difficult to measure.
GB
Jimboot
working on my new rig now.
Well done, exciting stuff. Photos to follow. Still waiting for the return of my MacBook!
Hi all
regards
Laurent
Jimboot
New rig taking shape. I feel the attraction from the coils when charged is similar to the metglas but not as strong. I get the 'cogging effect' from them tho.
