dradak1
Quote from: k4zep on January 28, 2010, 06:57:44 AM
I like the smile on your face and your enthusiasm!  Keep it up and keep messing up those cutting boards!
Ben
Let’s hope that he will not be chased by someone who was sharing that cutting board with him for other purpose.  :D
captainpecan
Quote from: Jimboot on January 28, 2010, 03:47:20 AM
Let's not forget to giggle.
My 1st circuit board.
And the many sleepless nights with your brain running constantly begins!!! lol...  Nice work, most of us have those first builds that everyone looks at scratching their heads saying "What the hell is that?", lol...  Hey, sewer pipe and duck tape are in my orbo replication, so some things will never change!  We use what we can.  Good to see you hit the bench, that's where the learning really happens.
woopy
well sayd Captain
here some results
I changed the rotor from 8 to 4 bigger magnets and i got the nice AC trace you spoke yesterday.
Than i have research a mean to get the pulse exactly at the peak of the generator wave . And progressively by trial and error i got it . But it seams that the peak is much Higher than the one of Ossie. ??
I have noticed that my reed switch  move a lot when the the magnets pass by, so i am now trying to fix all this much better because it needs great precision to get the Ossie effect.
good night
Laurent
Bruce_TPU
Hello ALL,
Still around, just took a time out to finish my website.
Part 7 of my snail build...LOL
http://www.youtube.com/watch?v=CMRUjg0R7yQ
Cheers,
Bruce
Jimboot
Tried to post this earlier but had some probs. This is a photo of arcing in my reed switches on Ossies toroidless design. Still having issues getting it tuned to run but the arcing corresponds with voltage spikes in the battery
