Omega_0
The 1 amp for input may not be the average value, it could be peak current. The real current would be I*dutycycle. There was only one pickup coil which was shorted and connected to a current probe.
The demo was stupid and was probably designed for a layperson, but even a layperson will gain nothing much out of it. Well CEOs cannot be compared to engineers :D
They did not measure I and V (on both input and output sides) separately, simply displayed integration of both, in a vague manner. He did not describe the scope connections very well. So nothing much can be said about the "proof" part. The real proof will come from replicators, not from steorn.
Anyway, summing up the relevant info for replicators here (as much as I could understand) :
1- There is an input part and an output part of the device and both are independent i.e don't influence each other. (see the boxed part in the pic below)
2- The input is taking just over an amp (peak most probably)
3- The output is picked up via air core coils. The actual output is NOT the collapsed EMF of toroidal coils.
4- You can get the collapsed EMF power also which would be 108% of input (I may be wrong here, pl check)
5- The output side efficiency is infinite, because the input is nil as seen from the output.
6- The net "electrical out" to "electrical in" efficiency is 327%
7- COP is a bit more and will include KE of rotor + air and bearing friction in output.
8- The coils are turned on exactly at TDC and turned off at 25-30 deg from TDC.
9- There is no fixed efficiency. You can vary it according to design, like by placing the pickup closer to the magnets, or getting bigger magnets and coils. You can make it as efficient as you want.
10- RPM is 1300 in this case.
hekkmekk
@captainpecan
The 1 amp was meant for the demo orbos on the steady stream.
It wasn't referred to the one we saw yesterday.
Jimboot
Scope shot of D cell battery that is about 8 YO been sitting in a disused portable elec fence unit. 1.28 Volts 1100RPM. Am I right in assuming the fuzzy arrowheads are the coils & the 2 that are more prominent is where the switch is operating?
vorrex
Part 3 of yesterdays demo is now available here:
http://www.youtube.com/watch?v=MY-IZby6lIY
Still no sign of part 2 though.
Jimboot
This on 6V running at 6000RPM losing 0.12V/hour On this wave what pulse do I need to increase
