0 Members and 36 Guests are viewing this topic.
teslaalset
Quote from: teslaalset on February 01, 2010, 04:34:38 PM
Here's the corrected graph.
Quick Excel analysis learned me already this is close to the blue Steorn curve.
Excel analysis will follow.
Here's the Excel file attached.
Simulation of the power and integral of the power graphs are also attached below.
What I think is happening is:
1) the coil is powered for a very short period
2) next, the coil is shortened by the switch
3) next, the switch is opened, with some remaining energy still in the coil
4) a large spike is caused by opening of the switch while energy is still in the coil
5) area B is started. I still don't know what is happening here. probably necessary for degausing the toroid.
woopy
Hello PESE
take it easy everything allright !!
I know exactly the voltage of my alcaline battery     and if you go some post ago you will see that the testing began at 4.8 volt  on my alcaline battery     so i loose in 30 hours from 4.8 -to4,6 volts
yes of course you are right   my kitchen clock works pricesily since last year with only 1 AA battery   but   it surely would not have run 4 "heavy magnets on a crued bearing at 290 mean rpm for 30 hours
I am not proving here OU   i am simply feeling very intersting way to approach the goal.
to all
@ the italianer researcher  sorry   but i have ordered today some better meters to perhaps answer your questions, but of course feel free  to replicate the Ossie motor it is very easy to do   see prevoius post all is explained and if you already have the material to measure your results please keep us informed
oouuppss
In my previous posat i forgot the pictures
good night
Laurent
Jimboot
pese
Quote from: woopy on February 01, 2010, 05:46:20 PM
Hello PESE
to all
oouuppss
good night
Laurent
OK, if this is know, to all.
so that is not wondering, since bedini naudin  and and.
i will follow time to time ...
Gustav Pese
Jimboot
Ok my Ossie motor which is informing my new Orbo replication (see what I did there :)) has been running on a 1.5V Everready Energizer Alkaline D Cell for over 19 hours at 300RPM. It has shown steady at 1.25V dropping very occasionally down to 1.24 then back to 1.25. My noobie brain can only assume it is consuming what it generates. What is the big step in this situation to get something to self run. The battery tested in at 1.32 before I started the run. Does that mean there is .07V in use accross the circuit that I have to compensate for before I can think about a cap? Sorry for the electronics 101 questions.
Scope shot (I returned the CRT for a USB scope) below.
edit: resized & posted again
