maw2432
Quote from: Bruce_TPU on February 07, 2010, 04:31:17 PM
Hi Bill,
I will let you know in a bit, as I am just having time to play... LOL
You wind the secondary, strip the leads and join them together.  That is it.  They are not joined "electricaly" to the circuit, if I may use that word.
I will let you know if it works!
Cheers,
Bruce
http://energyfreedomreport.com
Bruce thanks,
Let me see if I understand, once shorted the secondary coil wires are then connected to one of primary wires?  If so does it matter which one?   If not connected at all,  then how does it effect the primary?    Sorry for  being so detailed.
Bruce_TPU
Hi Bill,
Cheers,
Bruce
Hey Bill,
Ok, having a shorted winding on the primary does indeed allow the current to flow, and reduces the need for much voltage at all.  I have just burned up some wires (too much current), no biggie... LOL  But I now must switch from my 12 volt sealed lead acid to a D Cell and see what happens.  Worst case, I put it onto my power supply.  I really want to go with a battery if I can.
Shorted secondary (my green winding) is not connected to anything but itself (shorted)
teslaalset
Quote from: PaulLowrance on February 07, 2010, 04:25:45 PM
The attached image should explain it. That's how it seemed to me from the start.
Paul, thanks for your thoughts.
I thought about this kind power flow, however that does not match with my thoughts on how the coil moves in the B-H curve.
Below my initial views.
Red is the area that is 'travelled' during the power pulse.
Blue is the one travelled after the coil power has ended.
[edit]
To close this loop, the remanent magnetic situation of the coil core needs to switch. This is probably where the magnet comes in. Any other thoughts?
PaulLowrance
Quote from: teslaalset on February 07, 2010, 05:02:37 PM
teslaalset, the BH curve you show is only for internal interaction, not simultaneous external-internal interaction. The magnet acts as an external field since it cannot form a close magnetic loop. You can't use the square loop BH curve in this case. The magnet forces a lot of the domains to align to its field. This requires a lot from the coil to counteract. It's almost a flat curve, practically no coercivity.
teslaalset
Quote from: PaulLowrance on February 07, 2010, 05:14:23 PM
That makes sense, indeed.
B.t.w. instead of a diode, it could simply be shortened as well.
(in case of reed switches or relais)
