teslaalset
Quote from: PaulLowrance on January 13, 2010, 07:33:17 PM
Hi,
The cores are only $2.65 each, and so far it appears to be the best matching core to Steorn's. I would think people would want to be encouraging to buy these Metglas MAGAMP cores, not discouraged, right?
I just had a quotation from Elna: MP2510P4AS    $12.14 each.
I have a strong feeling they think they got gold in their hands.
@ Ben, what did you pay for your MetGlas cores?
teslaalset
Quote from: PaulLowrance on February 08, 2010, 03:06:54 PM
teslaalset,
The Ising model applet shows:
1. As magnet is at TDC, and as the coil current begins to increase, the permeability is low. This is seen in the Steorn integrated power plot as a sudden rise-- see "Ref. A" in the attached image, violet text.
2. Due to the resistance of the circuit, the current reaches maximum, and the power disipation is relatively constant. This is seen in the Steorn power plot at "Ref. B" in the attached image.. In the Ising applet the permeability increases a bit, but this will not show up in the power plot because the coil current is now high, and hence the circuit is mostly resistance at this point.
3. The coil current turns off, and the diode bridge rectifier conducts. The Ising applet shows the permeability is very low as the field begins to decrease. This is shown in the power plot as a rapid downward slop-- see "Ref. C".
4. As the applied field on the toroid core approaches zero (caused by the pickup coil), the Ising applet shows that the permeability begins to significantly increase. This is seen in the power plot as "Ref. D"
Paul, what application did you run on that webpage? I see 3 different one's.
Or did you download the application and run that one?
teslaalset
PaulLowrance
Quote from: teslaalset on February 08, 2010, 04:31:27 PM
That's because your cores are a lot bigger, and contain ~ 4.5 times more material. I posted the calculation at this forum like last month. If works about the same price per amount of material.
PaulLowrance
Some people are trying to say the Orbo is a fake because the pickup coil is not glowing on the FLIR camera. Here is an analysis of the Steorn FLIR shots -->
http://globalfreeenergy.info/2010/02/08/steorn-flir-camera-analysis/
