0 Members and 72 Guests are viewing this topic.
gravityblock
Below is an illustration showing a toroid at 25o from TDC.  The illustration is showing the concept and should be used as a guide only.  If it was 30o, then the toroid would be closer to the rotor.  Also, if the core is smaller in diameter, then it would be closer to the rotor.
We need to have the greatest attraction force with the least amount of input energy for the pulse to make the core no longer attractive according to the gap between the core and the magnets.  Geometry and math can solve this issue I believe.
GB
happyfunball
@LarryC The Storn current trace appears to have a slight rise at the start. Are the Steorn and JLN traces showing the same timebase?
teslaalset
Quote from: happyfunball on February 09, 2010, 04:26:25 PM
At least they don't show same polarities.
B.t.w. keep in mind the Naudin's next step will most likely be using cores with higher permeability.
He's already referring to Nanoperm cores.
So, let's not draw conclusions yet.
LarryC
I don't know, but there are many Steorn traces that show a similar trace.
In the Steorn video 'Steorn examine Orbo replication attempts' they showed that opposite polarity magnets on the rotor will induce emf in the same direction when current (+ or -) is applied. Another, how is that possible? I'm sure this is another important key, any ideas?
Regards, Larry
happyfunball
Quote from: LarryC on February 09, 2010, 06:30:19 PM
Regards, Larry
Are you saying that many of Steorn's current traces show the same rise at the start? I thought their whole schtick was that it was perfectly flat.
