Omnibus
That's right. They show it clearly in their experiment but one has to see it for oneself. That's the main problem.
gravityblock
I've started a new thread for anyone interested in using Flux3D or other simulation software in order to simulate the effect of magnetic viscosity with the main focus on the needed code changes to demonstrate this effect, http://www.overunity.com/index.php?topic=8869.0
According to Sean McCarthy in 2007, they use an FEA package called Flux3D from Cedrat ( http://www.cedrat.com/en/software-solutions/flux.html ). Sean says, "I should point out that the system does require some code changes in order to demonstrate the effect which is based around Magnetic Viscosity", http://peswiki.com/index.php/Steorn#Software_Modeling
GB
freeorbo
Quote from: Omnibus on March 06, 2010, 09:54:24 AM
That's incorrect. The pick-up coil is the load.
It's a load on the rotor, not on the circuit. The circuit is unaffected by the pickup coil, that's the whole point of Steorn Demo 1, right?
the input current is steady and independent of what is going on with the rotor, right?
freeorbo
Quote from: gyulasun on March 06, 2010, 02:10:34 PM
However small pico or microamper current is consumed, it is dissipated in the 10MOhm inner resistance, WILL NOT GO BACK to the battery.
Right, that's my point. I agree with you 100%. And in the case of Larskro's video, the amount dissipated is the only amount consumed. He could input 20V and 200 amps,  or 4V and .31 amps; he'd still only be consuming the amount dissipated by the wire resistance.
An orbo circuit is just simply the current running through some wire. The only load on the circuit is the wire resistance. And the wire resistance never goes up, but does sometimes go down due to the inductive gain.
So any energy gotten back out of an orbo system should be compared not against the input power, but only against the resistive losses. Agreed?
exnihiloest
Quote from: gravityblock on March 06, 2010, 06:24:07 PM
Your partner has done nothing but intentionally twist the facts, along with you and a few others.  I've already posted how the facts are being twisted, and you keep insisting otherwise.
GB
I gave facts and possible explanations. You may agree or not agree, but please stop your ad hominem attacks.
Here is your problem, gravityblock:
http://en.wikipedia.org/wiki/Psychological_projection
