Reincarnate
Quote from: lumen on December 22, 2009, 12:29:17 PM
Well, this shows the effect does exist.
The problem with using ferrite is you need to know which ferrite you are using.
Ferrite used in typical transformers will have an extremely high saturation point because this is good for transformers.
The ferrite that should work best would have a low saturation point. Or possibly not even use ferrite.
Meanwhile, nobody seems to notice the pink elephant in the room which is the four sets of three disk magnets below the coils backed up with some iron laminates and the extra large hub above which probably contains another toroid magnet and core.
Thane Heins ring a bell? Steorns next controversy will probably be a patent fight since this does not seem to look anything like the original.
God created whiskey to keep the Irish from taking over the world so the Irish drank the whiskey and then created Orbo. Even Hitler had something to say about that.
Hitler reacts to Steorn's demo and launch of Orbo!
http://www.youtube.com/watch?v=xRk5ea5pA5Y&feature=related
hartiberlin
With this toroidal core saturation effect, setting muR to 1  one could also easily
build an overunity transformer with no moving parts.
Just make sure most of the magnetic flux from
a permanent magnet is attrated to the toroidal
coil´s ferrite, when the coil is not energized.
If you put an output coil into the airgap between
magnet and toroidal ferrite coil and only draw current
from it, when the toroidal input coil is not energized,
then you will have some kind of motionless orbo overunity transformer.
By the way, is it possible with FEMM to simulate also
BackEMF and CounterEMF in coils around iron ferrite cores ?
If yes, this could be modeled in FEMM too, to check for the best output.
Regards, Stefan.
Reincarnate
Quote from: hartiberlin on December 22, 2009, 09:00:28 PM
Regards, Stefan.
I think you may even find two wires going up through the shaft that connect to a coil. E.g., Thane Heins only using toroidal coils instead of I cores. Optical switches switch when coil is shorted to get past hump and using both sides of a magnet in a pulse motor. Compression yields free energy as coil mass is converted into atomic energy.
Not sure that it has as much to do with saturation as it does with pulse compression. The compression accelerates mass which converts mass into the atomic energy contained within the mass.
I don't think Thane really understands his motor beyond a classic EM which is why he feels it violates Lentz law. Lentz law does not apply to an accelerated mass. Many law of physics can be violated with acceleration and why people feel they are impossible, or violate 2nd law when they wrongly apply 2nd law to an open system since mass is fuel source which opens the system.
All free energy devices use acceleration to convert mass into the atomic energy contained within the mass as I described in earlier post. Cavitation is a form of acceleration, pulse compression is a form of acceleration, a laser can be used to accelerate, vacuum tube accelerates, electromagnet accelerator coil accelerates using pancake and coaxial coil from Tesla, etc. It t is all so simple to understand once you let go of all the BS you were programmed with regarding zero point, eather and college level physics and see big picture of the forest.
lumen
Regards, Stefan.
I had the same thought, but I was thinking two toroidal coils and one magnet.
The field would draw to one toroid then the other, back and forth. Each time passing through two separate winding in the gap to generate power. Like switched reluctance.
At resonance in the toroidal coils, one would believe it should produce OU if the Steorn principal is correct.
PaulLowrance
Here you go, a new photo taken from the demo, one for the skeptics,  ;)
