0 Members and 45 Guests are viewing this topic.
happyfunball
Quote from: rensseak on June 19, 2010, 03:06:37 AM
Maybe not yet but in the future? That is only the beginning.
And what progress do your experiments?
They've supposedly had Orbo technology for at least seven years. Why isn't their headquarters powered by it?
Omnibus
Quote from: happyfunball on June 19, 2010, 09:02:02 AM
The view that Earth is the center of the universe and everything revolves around it was around a bit longer--about 2000 years. Why did we have to listen to Copernicus and his revolutionary heliocentric theory? Seven years. Are you kidding me?
Bruce_TPU
Hi Omnibus,
Thank you for the picture.  It appears to be 30 awg wire or so.  Now, one more favor and please give me accurate dimmensions in mm.  Height, circumference, diameter, thickness of sides.
Thanks!
Bruce
Omnibus
Quote from: Bruce_TPU on June 19, 2010, 10:01:37 AM
Hi Omnibus,
Thanks!
Bruce
Now, here's  some further development which is even more interesting. I unwound one of the primary coils (recall the primary coil consists of two parts--reddish and yellowish wire) and wound it around a plastic spool I found lying around. The rewinding was done by having the two parts side by side and wind them as one on the spool. Then I connected the what appears to be bifilar and lo and behold, an even bigger OU effect. I'll post a picture but please bear with me since I was trying to finish and post an account on capacitance when this came about. Besides, there's not much to say about it, only the number of turns (425turns) maybe and that the wire is hair thin (you mention 30awg wire and if that's hair thin then it very well may be).
@omnibus, thanks again for your collaboration.
So if I'm not mistaken if you take the current and voltage, and multiplied these instantaneous values you should get a certain wave form indicating power. Now this waveform can be averaged over time. In excell this means adding up all these power values of a certain time period and dividing by the amount of values you added. In the case of an ideal capacitor or inductor the average power should be near 0W, for a resistor it would be some positive value, but in your case this integral should give a negative value. Can you please confirm this on the frequency with the highest cop. It's also probably best to only use a resistor at this frequency to compare its average value. I you like I can help with the visualization of the data. Thanks.
