0 Members and 27 Guests are viewing this topic.
Omnibus
Quote from: LarryC on June 20, 2010, 11:43:49 AM
Thanks, but I don't expect Omnibus to admit he's wrong even after he understands.
In the pass he didn't have any equipment and no testing that I've seen. He usually made a statement like 'It has been proven beyond a shadow of a doubt that this (insert thread device) is OU'. But, no matter how many people asked for proof, he could show no proof and never admit that he was wrong.
Now he has access to University level equipment, large University blackboard, and a University quality test stand as can be seen on page 215, #3220. Did he inherit a University?
His ability to mislead others, has gone up a 100 fold. So it may be worth the trouble to insert a little truth.
Regards, Larry
Cut out the insults at once. You're wrong, as I've already explained, and that doesn't allow you to insult people. You can't win an argument by insulting people. Educate yourself first and then you may find out how embarrassed you'll feel.
The funniest thing is that you don't realize that if I consider the cos(Phi) factor the OU effect I'm reporting will be way higher.
LarryC
Quote from: Omnibus on June 20, 2010, 11:48:43 AM
Okay, lets use your 700kHz with cursors as an example. I'll just use your R as I don't know what value is Z. The phase angle is close to 90, so I'll  use 88 as cos(90) is zero and that would make all answers 0.
True power at cursor b = 17 V  * .002 A * cos(88)     b = .002^2 * 63 Ohms * cos(88)
                             b = 17  * .002 * .034899          b = .000004 * 63 * .034899
                             b = .001187                            b = .000009
Omni power at cursor b = 17 V * .002                       b= .002^2 * 63
                             b  = .034                                b= .000252
You're welcome to show any other example, but since the cosine of all angles from 1 to 90 will be less than one, then True power answers will always be less than Omni power except at angle 0.
Regards, Larry
Omnibus
That's not only an incorrect way to calculate power but it makes the OU much higher than the OU I reported. It's for you to find out why. Let this homework teach you something so that you can get out of this silliness.
Bruce_TPU
Hi Omnibus,
Why not just increase the input power, at the frequency that shows the greatest OverUnity and then Rectify and Smooth the DC output for measurement.  This will (should) stop all of the arguments and show that either there is or there is not OU.  You may already have more than enough voltage to rectify it even now.
Keep up the good fight,
Bruce
LarryC
Quote from: A link=topic=8411.msg246043#msg246043 A=1277074577
That's not only an incorrect way to calculate power but it makes the OU much A than the OU I reported.
Not true, that is a total lie.
Lets keep in mind that you first stated this: 'The funniest thing is that you don't realize that if I consider the cos(Phi) factor the OU effect I'm reporting will be way higher.'
The math I showed using cos(Phi) factor in my previous post proved that you are wrong, your OU is not higher with the True power formula(from the displayed text). In both cases True power is less than Omni power(from your excel formula's):
'True power at cursor b = 17 V  * .002 A * cos(88)     b = .002^2 * 63 Ohms * cos  (88)
                              b  = .034                                b= .000252'
Isn't .001187 < than .034 and .000009 < than .000252 in Omni world?
But as usual, as you have done many times in the past, instead of being man enough to admit that you are wrong or show the math that is being presented is wrong, you decide to just state another lie.
It seems you have the delusional belief that just because you state an incorrect fact that people will believe you and you don't have to show any proof.
Quote from: Omnibus link=topic=8411.msg246043#msg246043 A=1277074577
'It's for you to find out why. Let this homework teach you something so that you can get out of this silliness.'
Homework for me? You did not even realize that the Cos of 1 to 90 angle, which is all less than one, would reduce the OU.
Regards, Larry
