infringer
Onimbus first off if you would like such a converter to be built, you may want to give some specifics of what ratings you are trying to achieve like:
Current type
Voltage level or range
If you are more specific you may just get what you ask for who knows... But it appears in every learning venture or asking for help being specific was always part of the criteria for getting an appropriate answer.
REGISTER AND BECOME A MEMBER RIGHT NOW!!!!!
........::::::::: http://www.energyinfringer.com  :::::::::........
"""""""everything is energy and energy is everything""""""
-infringer-
Omnibus
@infringer,
It would be great to try to reproduce these finding and I'll try to hel you as much as I can:
QuoteResistor (R) is at the top on the right the banding on the resistor should face north right? And what is the resistor specs and where to buy.
The capacitor (C) the negative lead should also face north correct? What are the specifications and where can I purchase this as well?
The pulse generator what type of pulse generator is this where can I buy it and how many legs and how does it solder into this circuit as well.
Where is the supply current coming from and what is the supply current and voltage and the supply is hooked to the pulse generator correct?
The resistor and the capacitor are from RadioShack. Don't know the exact catalog numbers but will check. The resistor is a 1W, 100Ohm metal-oxide resistor while the cap is 100pF cap. You can find them in those drawers almost every RadioShack has. I think it was the top drawer for the resistors as well as for the caps.
The power supply is a Hewlett Packard 8116A pulse/function generator. I guess you can use a different one. It just happened that I had this particular device. What I did was I mounted a female BNC (for some reason you won't find BNC's in RadioShack but luckily I had one lying around) onto a tiny board I got again from RadioShack. If you go back in the thread there a a couple of pics I posted of a similar setup. The female BNC was connected to the pulse generator via male to male BNC cable. RadioShack has such but they are very long. It again happened so that I had one (a foot short) lying around from previous research (sometimes you're lucky, you know). I guess, you can make one because, fortunalely, RadioShack has male BNC's.
So, once you have the female BNC connected to the pulse generator, what remains is to connect (solder) the R and C in series to the hot and the ground point of the female BNC. The voltage is measured across these two poins while the current is measured with the current probe after the resistor, as shown in the schematic. Now, current probe is an expensive critter (it brought me back with about $3000) so you may try with measuring current by dividing the resistance of the resistor into the voltage drop across the resistor.
That's for now. I can't think of anything more right now but please do ask questions if there's something unclear.
Omnibus
Quote from: infringer on June 26, 2010, 11:55:00 AM
Current type
The way I understand it, the converter should turn the energy stored energy in a cap into 700kHz voltage and current at the level seen in the screen shot I posted.
Bruce_TPU
Hi Omnibus,
Gteat information on the coils special winding! It remins me of a special type winding I saw on a patent...will post more info later.  Just moved and computer is not yet connected.
Wat is the ideal length of wire?  Have you tried using a thicker awg wir?
Groundloop_ could you help out Omnibus with a circuit for a converter?  Thank you!
Omnibus
Quote from: Bruce_TPU on June 26, 2010, 12:11:53 PM
Hi Omnibus,
I got this this effect also with the RadioShack magnet wire. I can't tell you yet what that dependence on the length is but the effect was seen when I only wound in parallel the wire from the two spools with the thinner wire (they are always selling three spools of magnet wire). The wire with the lowest agw never showed OU. Also, when I wound two lengths of the green and two lengths of the red (that is, doubled the length) the OU disappeared.
The main thing is the capacitor, however, and all my attention got diverted towards that element, abandoning the coils altogether (I'm still waiting for several toroid coils, a couple of them with metglas to arrive, but I don't think they would be of any use in view of the new findings).
