Hope
Anyone out there try making a Rodin motor yet?    ANY TEST results?    Can a Rodin coil be "barred" then charged like a PMH (permant magnet holder). If so is there any flux still happening?
happyfunball
Quote from: Hope on September 09, 2010, 04:55:41 PM
http://www.youtube.com/user/skycollection#p/u
Hope
Since we have constant torque unfettered by load will a heavy flywheel act like storage the faster it is driven?  Ed Leeds.. engine block was a nice size force storage battery perhaps!   Does anyone have any theories on how it was used, what may be missing from it now?
edit comment "Sky   that is NOT a Rodin Coil"
stevensrd1
I did something, Im not exactly sure, that now my motor I use to recharge a battery seems to show no back emf. What I was trying to do was make another pulse motor, like I wrote about and showed how to do in this part of the forum-->> http://www.overunity.com/index.php?topic=9737  Anyway I obviously broke something else in the motor then I intended to break, there cant be many things one can break, most likely a wire. The odd part is if I broke a wire,,then why can I put the motor on the digital meter and spin it by hand and get a voltage reading. Point is, I usually play around with such having one motor connected to another, then trying to recharge another battery with the second motor using it as a generator. But Like I said I broke something I did not intend to break because the motor wont run as a pulse motor with power applied,,however it produces voltage when spun, and I have it in another experiment charging a battery with it. The first motor spins the same as if there was no second motor connected to it. As I was saying usually when I have it done this way and connect the second motor to the battery to recharge, there is a speed decrease in the first motor as you can notice the torque or back emf in the second motor then. But with the broken motor Im using it shows no back emf,,no speed change in the first motor when hooked to the second battery to be recharged. I cant really reopen the motor to check it out cause its a cd motor which they are very hard to open up in the first place, as there is no metal flabs to bend with those kinds of motors, and the back of them warp slightly each time you open them up,,and opening them to many times there beyond even using anymore. All I recall doing was breaking that prong off on rotor as mentioned in the above link I posted, but something else had to have broken. Thats all really I can say about it, but there is no noticeable back emf or torque on the first motor when the second is connected to the battery to be recharged. And the second motor is putting out voltage as can be seen by the meter and spinning it by hand, plus I can watch the voltage slowly rise on the battery being recharged with the meter..Maybe someone understands what I did and can use that to some benefit..
