0 Members and 68 Guests are viewing this topic.
tinu
Quote from: broli on December 30, 2009, 01:15:09 PM
Before you belittle people educate yourself some more. In an ideal conductor current will rise linearly. An inductor is a very good example of F=ma where I is propotional to speed. If E is constant ie F then v or I will increase linearly. If you have a resistance on the other hand your mechanic system will have an counter force F=-kv exactly like wind friction. And as we know with wind friction a body will drop until it hits the thermal velocity in our case being the ohmic current limit. It will do this by starting out linearly and dieing off exponentially just like an RL circuit.
That is serious business my friend.
Do you have a link/reference/proof for that?
I admit superconducting is not my expertise but do I have to take your word for real?
At least I’ve always try providing links and arguments based on various references... Hope you can do the same. Eventually PM would be more appropriate instead of polluting the thread. We may reconvene when Orbo will be provided with superconducting coils...
Thanks,
Tinu
lumen
Consider the following condition.
The outer winding of coil #1 is connected to the toroidal winding of coil #2.
The outer winding of coil #2 is connected to the toroidal winding of coil #1.
When the magnetic field is attracted to the core of coil #1, the outer winding generates a current to saturate the core of coil #2 which increases the field through coil #1 until all the field is flowing through coil #1.
After the flow stagnates and the current starts to collapse, core #2 starts to become desaturated and some field flows through core #2. This induces a current in the outer windings of coil #2 which saturates the core of coil #1 causing all the field to flow through core #2 until it again becomes stagnant and things reverse again.
Self oscillating MEG?
Quote from: tinu on December 30, 2009, 01:53:15 PM
Thanks,
Tinu
What I say is common sense there's nothing mysterious about it. Look at the attached image for the math. This also explains why current flows indefinitely in an super conductor. This is newtons first law, there's no force acting on it so velocity remains constant.
This has lead me through some peculiar alleyways these last days.
Omega_0
Its interesting to see that JLN's V2 with 6 W input and about 800 rpm (guessed from frequency ???) is very close the clanzer's build shown here:
http://www.youtube.com/watch?v=Ev0B-_2PcMk
with 8 W input and 1130 rpm.
wings
my be it is a small effect .... but put the coil face to face to the magnet you can use also the Vector potential effect to push the magnet away, instead to only saturate the toroid.
http://jnaudin.free.fr/vpexp/index.htm
