PaulLowrance
Is there a cure for a wobbly drill press? On now on my 3rd eOrbo replication attempt! The drilled holes are lopsided, lol.
BTW, Happy New Year!
ATT
Quote from: PaulLowrance on December 31, 2009, 03:59:03 PM
Happy New year, Paul.
Not much to a drill press:
- Roll your bit on a flat surface to see if it's bent.
- Make sure your table is at 90 deg to your bit, use a square (not an adjustable t-square).
- Open the top, grab the pulley and see if you have play in the bushings.
- Whack the chuck with a chunk of wood to make sure it's seated.
- Make sure the inside of the chuck is clean, no shrapnel in there to offset your bit when you insert it and tighten it down.
Tony
Groundloop
Members on this forum,
My solid state Orbo generator is completed.
First test:
Connected power to oscillator, adjusted oscillator, no magnets on the coils, output was zero volt.
Attached N35 Neo magnets (crappy magnets) and the output was 180 Volt AC no load voltage.
Will be back soon with more testing.
Groundloop.
k4zep
  Is it a wobbley drill press or wobbly bit.  Use VERY SHARP BIT, use a Forstner bit, go VERY SLOW, use right RPM for material.........
Ben
k4zep
Quote from: Groundloop on December 31, 2009, 04:15:00 PM
Members of this forum,
First test:
Turns in (Inductance), Turns out (inductance) inductance with magnets?, Voltage in?????  Current out into load.
Respectfully
Ben
Groundloop.
