0 Members and 35 Guests are viewing this topic.
Groundloop
All,
Attached is my new switch. My motor now runs at 0,2A @ 12,31 Volt.
I have also found that mounting magnets at some angle on the core
will let the motor runs a huge faster! My angle was 45 Degrees from TDC.
Groundloop.
PaulLowrance
Groundloop
Bruce_TPU
Hi Groundloop,
What was the result of your attempt at a solid state device?  You had mentioned that it had shown 180 VAC.
Do you have a Video of the speed improvement by adding the magnet to the toroid?  Did adding the magnet change the input power at all?
Thanks!
Happy new year,
Bruce
plengo
@Groundloop,
so how is the testing of you solid state orbo? I am dying to know more about it.
Fausto.
