0 Members and 73 Guests are viewing this topic.
Topguner
Quote from: PaulLowrance on December 15, 2009, 09:46:14 AM
It's not frictionless. It might run a month, two tops on that battery.
If it is putting out enough power to recharge the battery then wouldn't it run indefinitely?
markdansie
Once again, it is nothing but a publicity trick. If they cant close loop it with a cap then they have nothing.
It is sad to say the least they continue to get away with this.
It would have been nice to have some meters and tourque devices....it gets down to power in and power out.
Mark
markdansie
This device could run for months on battery power, if they really had something they would use a cap and close loop it. Sadly , just another publicity stunt.
No one has ever published a peer review paper on the input and output of any of their devices.
It have never been independently tested and peer reviewed in other words. Speaking of works the accademics use the word appears rather than any definitive language. When you test something it either does or does not. Its a bit like binary logic. Greay areas still have results without explanation.
The lack of interest this time is they have no credability, and it appears they will have none at all after this little stunt.
After millions of $ in investors money this is all they have to show. Sad
Mark
mscoffman
This looks like a Bedini pulse motor on toroids.  :)
Battery must mean 10Kma hours. Seems like a well
designed pulse motor should be able to quite a while
on a single "D" battery. Makes me wonder if Steorn
doesn't read overunity.com
:S:MarkSCoffman
Cloxxki
If it's such a low-friction no-work spinning, no wonder really that it screeched to a halt when a couple of TV cam lights were pointed at it at a previous launch. Tight tolerances. So now, a controlled lab showing. The fact that it runs down is a btter disappointment. At least use 1 battery to charge multiple others to full capacity or something.
Really makes you wonder what their motive is. To scam the world and then come forward with it? Get money from someone, for nothing? Or just wild ignorance and vlind belief?
Still hoping there will be more...
