Mostly Permanent Magnet Motor with minimal Input Power
Started by gotoluc, December 07, 2009, 05:32:38 PM
Khwartz
gotoluc
Quote from: Khwartz on August 13, 2014, 12:21:27 AM
Hi Luc! :) How is going your reactive genertor ? :)
It ended when TinMan replicated it to see if the power was coming from the exciter field of the alternator. Looks like I was tapping into it without affecting the prime mover. So it was not really a free gain, more like a transfer of energy.
Luc
Khwartz
Understand!  VAR are all about pure movement of energy stored ;) But could be it is not "all the scene" as the present academic models of electricity look not enbounding all the stuff. Didi you read Eric P. Dollards writing?
Anyway, regarding your mostly permanent magnets motor, did you make progress compaire to you nice vid where you started from 0.3 N to 25 N? (If my calculations are correct).
BTW, please remember Luc that  P = W T^-1 = (M L^2 T^-2)T^-1 = (M L T^-2)  (L T^-1) = F V, "F" for "force" and "V" for "velocity"? Then measurements of the pulling force is very good to see your progress but not to get the efficiency (would be overunity or not). In your vid you did not compare power against power, right? Only force against power, as we discussed already last year of I remember well ;)
gotoluc
Hi Khwartz,
I have next to no schooling. The things I can do are mostly self taught. The experiments I do are my way of trying to learn more in hopes that one day I'll know enough to build a device to be energy independent.
I don't know why but learning all those math equations does not interest me.
I've always been hands on and not into reading patents and theorizing about this or that.
If I find something interesting from the stuff I build that's not commonly done, I share it and hopefully the more knowledgeable ones will find a use for it, suggest different tests or explain in a laymen way why it's not useful.
Anything thrown at me from an academic level is like water on a ducks back.
Luc
woopy
Hi Luc
thank's for your very clear explanation.
I tried to use the setup as an alternator, and connected 2 opposite LED, so they light alternatively, and it works very well. I am amazed how bright the LED are shining with very slow movement of the coil.
And yes , i think it can be very much improved by adding magnets and cores all arround the coil.
Thank's for sharing
Laurent
