Mostly Permanent Magnet Motor with minimal Input Power
Started by gotoluc, December 07, 2009, 05:32:38 PM
telecom
Quote from: tinman on August 24, 2014, 10:04:11 AM
A cap with a set value(uf) and set voltage,will have X amount of energy(joules).After running the test,IF there is any voltage left in the cap,you simply calculate the joules of energy left in the cap,and subtract that from the amount you started with in the cap befor running the experiment.This is a very accurate way of seeing how much energy you used in the test.
Where will you get a cap with an exact value - they all within at least 10 %
gotoluc
Hi everyone,
I'm working on building a Super Tandem version of the Mostly Magnet Motor
Here is a video update of the building process
Link to video: https://www.youtube.com/watch?v=XhDnqw_le88
Luc
telecom
Quote from: gotoluc on August 24, 2014, 11:06:57 PM
Hi everyone,
Luc
Great work plan - looking forward to completion!
ARMCORTEX
Not useable as a lifting tool, you will dampen out the resonance, try on any physics sim.
Subwoofer for lowbanwidth frequency range is all I see good here.
What you need, is rotating eccentric mass on the shifting platform.
Now you have a force that can be tapped into.
I remember some russian guy on YT who had similar PUMP idea but for reciprocating motor, nope.
But as always, as is always the case, higher torque tends to dampen out the resonance.
tinman
Quote from: telecom on August 24, 2014, 07:27:33 PM
Only as per the spec's on the cap. A decent DMM will give you the correct value,and this is the value you use. An AC cap can be used in a DC situation aswell,and this way the flyback could also be collected.
