Mostly Permanent Magnet Motor with minimal Input Power
Started by gotoluc, December 07, 2009, 05:32:38 PM
DreamThinkBuild
Hi Luc,
Great work on the build.
I had two untested ideas for your design one is a linear generator.
Instead of having continuous bars along the edge replace them with steel pipes. A split is in the middle so that when the coil is powered it makes the top of the pipe south while the bottom is north. The output coil will see this change as it collapses toward the north pole. I'm not sure on how this will be effected by the opposing field though. Also a split may be needed along the side of the pipe so that eddy currents are minimized. It might be something to test.
The rotary idea is just a thought in progress. Magnets can be used to polarize the metal as all north. There is a falloff toward the center but it is still north facing, this difference is needed otherwise we end up with a static system. The gates would have the strongest field to push from while being pulled toward the next gate.
The polarizing is based off of this observation:
http://www.overunity.com/14843/are-partial-monopoles-possible/
This current design has issues but maybe it will inspire a better idea or design.
gotoluc
Hi DreamThinkBuild,
Thank you for your post and sharing your ideas and illustration work.
The way I have come to understand the fields around an electromagnet coil is, it is not just North South on each end of the coils.  Actually half way through the thickness of the coil there is a blotch wall and the polarity shifts.
It would look more like you illustration below where I have identified the poles on one side of the coil.
This is why in my design the magnets poles are not on the vertical plain like your illustration.  They are on the horizontal plain with the blotch wall half way trough the coil windings.
Using a coil of the same thickness as the magnet will gives most torque output.
Look at the below video and take close attention to the magnet poles. Here I demonstrate you can double the torque when you use the coils outer magnetic field which is in opposite poles of the coils inner field.
If this wasn't the case we would have a cancellation of torque since the magnets on the outside cores are in opposite field of the inner cores.
Link to the video: https://www.youtube.com/watch?v=-eTQ49RcFKM
Let me know what you think and understand
Luc
Khwartz
@ All: Please, skip the algebraic developments of this VERY-VERY LONG spot, if you're if algebra is not really your friend ;)
Quote from: tinman on August 31, 2014, 05:22:38 AM
yes-not sure why i put watt hour's,should just be watts.
So would we use 1/2 G in this case? 4.45m*/s
So as 1 watt /4.9x1kg=204mW.
A pull force of 1kg @ 204mW of power?.
No problem Brad, for the adding hours; aren't we here to correct, give ideas and share experiments to each other, in what we like the most to do? :)
For your question: no, cause we don't even have to care about G! Lol, cause it is NEUTRAL in the cycle, as I see it and as per the following algebraic operations:
Say:
• Wmt, the total effective mechanical energy of the whole cycle
• T1, the time period of lifting
• T2, the time period of droping
• Wm1, the effective mechanical energy of the lifting
• Wm2, the effective mechanical energy of the droping
• We1, the electrical energy consumption of the lifting
• We2, the electrical energy of the electromagnetic flyback at the droping
• Wg, the gravitational energy as per: Wg = F × g = (M × L) × g, with:
• F, weight [Newtons]
• M, mass [kg]
• L, crank or lifting or droping length [meter]
• g, gravitational acceleration, or "gravitational intensity field"
• a, the ratio of electrical energy losses respect the electrical energy consumption
• We': effective electrical energy, as per We' = We - a × We = (1 - a) × We
• A, the conjugated quantity of "a", "1 - a", which is the corresponding coefficient which allows to obtain the effective electrical energy directly from the electrical energy consumption: A × We = (1 - a) We = "effective electrical energy" = We'
• b, the ratio of mechanical energy losses respect the difference (electrical energy consumption - gravitational energy)
• Wm': effective mechanical energy, as per Wm' = We' - b × We' = (1 - b) × We'
• B, the conjugated quantity of "b", "1 - b", which is the corresponding coefficient which allows to obtain the effective mechanical energy directly from the effective electrical energy minus the gravity energy "Wg" when lifting, but plus the gravity energy "Wg" when droping: B × (We' +/- Wg) = (1 - b) × (We' +/- Wg) = "effective electrical energy" = Wm'
• c, the ratio of electrical energy flyback respect the electrical energy consumption of the lifting,)
• Wm": effective mechanical energy returned, as per Wm" = Wm' + c × We1
• C, the conjugated quantity of "c", "1 + c", which is the corresponding coefficient.
● Wmt = Wm1 + Wm2
● Wm1 = [We1 - a × We1 - Wg] - [b × (We1 - a × We - Wg) ]
○ Wm1 = (1 - b) × (We1 - a × We1 - Wg)
○ Wm1 = B × ( (1 - a) × We1 - Wg)
○ Wm1 = B × (A × We1 - Wg)
● Wm2 = [We2 - a × We2 + Wg] - [b × (We2 - a × We2 + Wg) ]
○ Wm2 = (1 - b) × (We2 - a × We2 + Wg)
○ Wm2 = B × ( (1 - a) × We2 + Wg)
○ Wm2 = B × (A × We2 + Wg)
○ Wmt = [ B × ( A × We1 - Wg) ] + [ B × ( A × We2 + Wg) ]
○ Wmt = B × { [ A × We1 - Wg ] + [ A × We2 + Wg ] }
○ Wmt = B × [ A × We1 - Wg + A × We2 + Wg ]
○ Wmt = B × [ A × We1 + A × We2 + Wg - Wg ]
○ Wmt = B × (A × We1 + A × We2 ); QED.
Note 1: In fact I didn't care of the time periods cause the time frame is fixed (even if not necessarily equal).
Note 2: I didn't care too of a spring. I considered that at the end of the first period, the lifting one, the mass is pulling back down by the gravity itself, so then no need of a spring (little more complex equations if we care! ^_^ ). And I have considered that at the end of the second period, it would have no returning mecanical energy system, so all the droping energy lost (which is placing us far below in efficiency than with a spring to reflect the energy or if a mechanical flywheel with a link).
Note 3: The electrical supplier voltage is only applied at the beginning of the lifting period.
Note 4: I used to use "expletive parentheses", they are to help the reading and understanding of the equations, even if it is not "mathematically necessary": "(...)", "[...]" and "{...}" is a personal use of parentheses to signify the different level of intrication, like: { [ ( ...) ] }. ;)
THEN, If I haven't messed up in my operations, it comes an interesting equation, imho, Brad: it the one of the conditions of o.u. for the device in the conditions I've just described:
As fixed time frame,
COP of mechanical output under electrical consumption
= mechanical output power / electrical consumption power
= mechanical output energy / electrical consumption energy
= Wmt / We1
● COP = Wmt / We1
○ Wmt = B × A × (We1 + We2 )
○ Wmt = B × A × (We1 + c × We1)
○ Wmt = B × A × (1 + c) × We1
○ Wmt = B × A × C × We1
○ Wmt / We1 = (B × A × C × We1) / We1
○ Wmt / We1 = B × A × C = COP.
So, as we have to have:
● COP > 1
so, we have to have too:
● Wmt / We1 > 1
○ B × A × C > 1
Then, we have our basic condition as a low estimate (remember, we didn't care of any spring reflection or mechanical flywheel):
○  C > 1 / (B × A)
☆☆☆☆☆☆☆☆   C > 1 / (B × A)  ☆☆☆☆☆☆☆☆
Example:
If,
= 0.10, or 10%, so A = 0.9,
= 0.10, or 10%, so B = 0.9,
We get:
C > 1 / (B × A)
○ C > 1 / (0.9 × 0.9)
○ C > ~1.235
So, to have o.u. we should have
> 24%.
○ For a = b = 20% ; c > ~57%
○ For a = 5% and b = 20%, or for  a = 20% and b = 5%, c > ~32%.
The problem we hmcan see while checking the equations for the system with a spring at bottom, is that if Wm2 would be transferred as per "d" spring coefficient losses "d", to the third time, BUT AT THE END OF THE THIRD TIME, ALL THE MECHANICAL ENERGY TRANSFERRED IS CONSUMED BY THE GRAVITY, so Wm4 = Wm2 :/
Then, we realise that luc's arrangement with 2 springs is decisive!
Indeed, it allows us the transfer each mechanical energy of each time to the next, as per the spring losses coefficient "d", and not consuming it just because of this gravity.
TWO SPRINGS SYSTEM WITHOUT GRAVITY INVOLVED:
After 34 pages of algebra and calculations, soon 24 hours non-spot of checking and rechecking ^_^, I got these following equations which state the conditions for overunity COP with my simplified operations.
The simplifications are:
▪ considering losses or gains always linear, proportional, when it not necessarily, and
▪ equalising the losses or gain coefficients as A = B = C = D = K, with:
□ A, coefficient of electromagnetic losses
□ B, coefficient of mecanical losses
□ C, coefficient of reflection losses (due to the springs)
□ D, coefficient of electromagnetic flyback gain
We see then that the NET ENERGY GAIN for the 2 first periods, for example, are: (we note We1 = We2 = constant = We)
● T1:
G1 = Wm1 - We
= A × We - We
= (A - 1) × We
-> a loss
● T2:
G2 = Wm2 - 2We
= (W,mech + W,ElectromagneticFlyback + W,Electrical Excitation) - 2We
= C × [ B × (A × We) ]
+ D × (A × We)
+ (A × We)
- 2We
= (A × B × C) × We
+ (A × D) × We
+ A × We
- 2We
= [ (A × B × C) + (A × D) + A - 2 ] × We
Then, to have COP overunity, we need:
● G2 > 0
So:
● [ (A × B × C) + (A × D) + A - 2 ] × We > 0
○ (A × B × C) + (A × D) + A - 2 > 0
○ (A × B × C) + (A × D) + A > 2
○ A [ (B × C) + D + 1 ] > 2
Setting A = B = C = D = K,
○ K [ (K × K) + K + 1 ] > 2
○ K^3 + K^2 + K > 2
○ [ (1 - K^4) / (1 - K) ] - 1 > 2
○ (1 - K^4) / (1 - K) > 3
Numerical examples:
• For K = 0.5 = 1/2, (1 - K^4) / (1 - K) = 30 / 16 = ~1.8 and 1.8 < 3; no overunity.
• For K = 0.75 = 3/4, (1 - K^4) / (1 - K) = 175 / 64 = ~2.7 and 2.7 < 3; no overunity.
• For K = 0.8 = 4/5, (1 - K^4) / (1 - K) = 369 / 125 = ~2.95 and 2.95 < 3; no overunity.
• For K = 0.9 = 9/10, (1 - K^4) / (1 - K) = 3,439 / 1,000 = ~3.4 and 3.4 < 3; WE HAVE OVERUNITY.
This means that with 10 % losses for each kind of losses encountered here and for 90 % of electromagnetic flyback recycled, the numbers say that we would be able to have overunity with these first calculations.  :)
But now, here is "The Big One",
THE OVERUNITY EQUATION ON LONGUE PERIOD OF TIME:
□□□□□ COP = { [1 / (1 - K) ] - 1 } / K □□□□□
And the solution for COP > 1 is:
□□□□□□□□□□   K > 0.618   □□□□□□□□□□
Means that theoretically, if my calculations abd reasoning are correct (and you may correct me at anytime):
WE SHOULD BE ABLE TO GET AN OVERUNITY EVEN WITH 38.2% OF LOSSES AND ONLY 61.8% OF ELECTROMAGNETIC FLYBACK. :P
Well, I have made my 24 hours around the clock now, hope few of you guys will appreciate the work!  ^_^
Regards,
Didier
Khwartz
Quote from: DreamThinkBuild on August 31, 2014, 01:37:34 PM
Hi Luc,
Very Well Done for the design and ideas!  :)
tinman
Quote from: Khwartz on September 02, 2014, 02:31:24 AM
Say:
• M, mass [kg]
● Wmt = Wm1 + Wm2
= Wmt / We1
● COP = Wmt / We1
● COP > 1
● Wmt / We1 > 1
○ B × A × C > 1
○  C > 1 / (B × A)
Example:
If,
We get:
C > 1 / (B × A)
○ C > ~1.235
> 24%.
● T1:
G1 = Wm1 - We
= A × We - We
= (A - 1) × We
-> a loss
● T2:
G2 = Wm2 - 2We
+ D × (A × We)
+ (A × We)
- 2We
= (A × B × C) × We
+ (A × D) × We
+ A × We
- 2We
● G2 > 0
So:
○ K^3 + K^2 + K > 2
Numerical examples:
Regards,
Didier
Ok-something went wrong in translation there.
I am trying to convert a constant pull force x watts-no moving parts.If we are to lift a weight of x amount by a distance of y amount in a fixed amount of time,then that is much easer. But to convert a non moving pull force x continuous watts input is a little harder.
What we want is to be able to hook up the scales to the moving coil,and get a pull force. Then we also have a stedy whatt input aswell-nothing moves. So we want to go say 500 grams pull x 1.2 watts input,and then be able to calculate efficiency from that with the correct math.
