Mostly Permanent Magnet Motor with minimal Input Power
Started by gotoluc, December 07, 2009, 05:32:38 PM
DaKrampus
Same here
thank you luc for pointing me to this thread in this forum.
I am very impressed!
The only question I have is: how do you get to 0.78 volts...
This is not a voltage I would have preset on my power supply.. I meen I probably could as it is a lab grade power supply where i can preset anything between 0.1 and 30 volts and 0.1 and 5 amps..
but I would not have set it to 0.78 by intuition.
so i was wondering.. is there a special reason?
Luciano
gotoluc
I was having some Youtube link problems with the above link which was going to the previous video even though it was a different link ???
It's fixed now
Luc
Farmhand
Luc, Aren't you just getting closer and closer to 100 % efficiency ? And when you get the best possible efficiency you can get won't
that be the closest to 100 % efficient you can get ? Is there an efficiency rating for those lifts and what an OU lift would figure as ?
Please forgive my "Apparent skepticism" and feel free to ignore my questions if you wish.
woopy
Hi Luc
Thank's very much for sharing
Beautifull work great bravo
Can't wait for the next videos
Laurent
synchro1
Quote from: gotoluc on September 26, 2014, 10:39:51 PM
Hi everyone,
here is a quick 2nd test of the Triple M Super build.
Link to video: https://www.youtube.com/watch?v=f6pc-XNS9uo
The results are for one coil and two wire strand connected in series
The simple 1 inch wide Triple M Pulled 500g for 0.43 Watts
The 8 inch Super build single coil one stand gave a result of 2Kg Pull for 0.43 Watts
and now the 8 inch Super build single coil 2 series stands gave a result of 2.5Kg Pull for 0.43 Watts
So by using only half of the 8 inch Super Build we are pulling 5 times more then the one inch build
Stay tuned for the full results of the Tandem (double) Triple M Super build
Place your bets on what you think it will pull for 0.43 Watts
Luc
@Gotoluc,
Are "2 series strands" the same as "Series bifilar"? I forecast a very exciting historical precedent on the approaching horizon!
