Mostly Permanent Magnet Motor with minimal Input Power
Started by gotoluc, December 07, 2009, 05:32:38 PM
dieter
Hanon,
I agree one can find the bucking coil in many concepts. Yet it bends my mind... Each coil would generate a CEMF, but as the currents collide at the center tap, no current may flow at all ..? And of cource, no CEMF.
Have you successfully obtained any current flow from a bucking coil?
Or is it maybe something for HF, so slight diffrences between the coils allow the current to pass one by one?
BR
gotoluc
Quote from: hanon on January 04, 2015, 07:21:27 PM
Hi Luc,
This post is about your video:  https://www.youtube.com/watch?v=PTykNjDD0CM
It is just to reference you, for your info,  this other video about this scheme , published in hyiq.org about Bucking Coils:  https://www.youtube.com/watch?v=Z-V1z2TdQJA
I suppose that if in your video you would have used an intermediate tap between the CW coil and the CCW coil to extract the induced voltage you would have got current without the Lenz effect...
The concept about bucking coils is very interesting to me, and it seem to have been used in many overunity devices: http://www.hyiq.org/Downloads/Guidelines%20to%20Bucking%20Coils.pdf
Thanks for remembering me sharing the beginning concept of this hanon
I suppose you could be right but what matters is to find the use for the effect and share it as Chris Sykes is doing!
I will be testing his version real soon and who knows, maybe I'm kind of testing this now without knowing lol: https://www.youtube.com/watch?v=9LK2C4qBY1Y
Thanks for taking the time to bring it to the attention of this topic
Luc
hanon
Quote from: dieter on January 05, 2015, 08:20:11 AM
Hanon,
Hi Dieter,
I have not test it yet but I have guessed some configurations which can get induction along the center tap of both bucking coils.
What about an aligned configuration as:
INDUCER (N) ---- ONE BUCKING COIL ---- ONE BUCKING COIL ---- (N) INDUCER
Where both inducers are creating a North pole toward each bucking coil (same inducer poles facing each other: North-North). This way each bucking coil is transversed by a different inducer field : one inducing in CW and other inducing in CCW, the same as the wiring of both bucking coils. With this configuration the induced current is extracted in the center tap. Now the question is if there is Lenz effect??
dieter
Basicly, when there is a current flow then there is a CEMF,  and Lenz is slapping his "law" right into our faces...again  :'( . If the two parts of the bucking coil would share the same space then they would neutralize eachother's CEMFs, but I don't know if any current would flow if both parts have eg. north poles on both ends, or alternating both north, then both south... Maybe something that could be simulated in FEMM.
BR
rushi95
Hi Gotoluc and others,
I am new to overunity forum. I did go through all the videos of Gotoluc and it did show very interesting effects.
This forum is inactive but I am not able to draw proper conclusions from the present conversation.
All the experiments done by Luc confirm that the magnets add strength to the solenoid. However, OU is not reached because of the generator effect. But I think these experiments should have indeed changed how solenoids/electromagnets are used today. Any one is aware of using these experiments in the real world? Or I am missing something due to which it will not work.
