Mostly Permanent Magnet Motor with minimal Input Power
Started by gotoluc, December 07, 2009, 05:32:38 PM
0 Members and 25 Guests are viewing this topic.
synchro1
Here's a short video of the friction bearing and spline on the Kundel rotor:
https://www.youtube.com/watch?v=1Vkjh7i4nnU
Look at the size of the huge neo discs backing the bifilar. The coil has a Hi-perm ferrite core. When the masking field, amplified by the core inductance, implodes; The inrush of field strength from the backing magnets generates very powerful output!
The Kundel rotor only generates force one way for 180 degrees, so we need a second chiral rotor to complete the revolution. The second rotor can attach with a few popsicle sticks to the first: The masking coil can generate any amount of reverse attraction force depending on input.
synchro1
Sailboat motor
Here the "Opposed Kundel Rotor Cage" is connected directly to a balanced propeller drive shaft and held into place by one bearing attached to the frame: The switch would move to the rail frame.
synchro1
Look at the cold molded ferrite core:
This powerful core allows the copper coil to equal and surpass the Neo backing magnets in magnetic force. The core changes polarity and joins the PM's in sympathy to generate a powerful BEMF output in the coil. The pyroclastic like formation of the ferrite strengthens the magnetic domains.
synchro1
Look at how I crafted a Kundel rotor from Washtub drain motor parts: The tub motor at the base can generate A.C. power.
https://www.youtube.com/watch?v=cZqcySvM-M4
synchro1
