Mostly Permanent Magnet Motor with minimal Input Power
Started by gotoluc, December 07, 2009, 05:32:38 PM
synchro1
circumferential magnetization of an arc segment; a plastic collar can secure 8 arc segments around the ceramic bearing.
synchro1
this video shows permanent magnet fields changing polarity and running a rotor;changing pm polarity.
this video speaks for itself; this motor can run from one limit switch because the solenoid magnets are in spring repulsion;
https://www.youtube.com/watch?v=3wG8ORZIkOc
synchro1
Magneticmotofun's magnet ring and core plunger produces the same gate kick as the kundle motor. The reguaging magnet output in the solenoid coil would return the input and allow this design to run free of charge.
Wiring the SPDT switch behind the solenoid would allow the PM's to oscillate in Adam's resonance and power the diametric rotor in a wash tub drain motor from the side to generate A.C. current.
This solenoid is a "Neutralization Pulse" GAP style motor that generates an implosive BEMF that returns its own power pulse!
synchro1
Switch position:
Magneticmotofun
The SPDT switch moves to inside: This triggers an "Attraction Neutralization" pulse that powers the piston away from the coil. I succeeded in spinning a Morin washtub drain motor diametric by pumping a ring and ferrite piston in opposition next to the case.
synchro1
The throw on this plunger is sufficient to turn the diametric wash tub motor rotor: I need two hands to demonstrate that effect in a video, but believe me it's real!
https://www.youtube.com/watch?v=2yyJiBOCaRg
