Mostly Permanent Magnet Motor with minimal Input Power
Started by gotoluc, December 07, 2009, 05:32:38 PM
synchro1
2 tiny coils trigger 40 magnets of force per cycle. The coils only equal the force of 2 permanent magnets.
What's the COP? Quick finger math tells us the COP is 20 times Overunity!
synchro1
12 volt electro-magnet relay coil; 3/4 inch n52's. With a high enough amperage the electromagnet can develop a significantly stronger magnetic field than a permanent magnet.
synchro1
synchro1
Re: Solid State Generator via Electromagnets + Halbach Array
« Reply #8 on: July 11, 2010, 07:36:45 PM »
Picture a Hallbach array sandwiched between two rotor wheels with staggered iron cleats attached along the edge of each of the insides, above and below. Activating the second and fourth electro magnet would make the Hallbach magnetic field shift from side to side with double the strength, attracting first the overhead then the staggered rotor cleat beneath; like the Art Porter design, a different coil assisted magnet motor, with a five to one pay off, strength doubling on each side! The Tesla bifilar high volatge magnet coil is wraped exactly like a Joule Thief, two wires three ends. The beginning of one wire attached to the end of the other. Twice the magnetic strength of a single wrap solenoid for the same wire length and input!
« Last Edit: July 11, 2010, 09:21:01 PM by synchro1
synchro1
2/5's of the power stator's force comes from the electro-magnet coils. matched by 5/5's of pm force, 8/5's of the total force costs 2/5's in input. this would lower the cop to 4.
Twice the magnetic strength of a single wrap solenoid for the same wire length and input! turned out to be mistaken. proved to be the same.
4 throat depressors or popsicle sticks and rubber bands can form a solid, quick and dirty, planer halbach array form.
