mass can slow "time".
Started by nitinnun, December 07, 2009, 08:29:41 PM
nitinnun
time is not an energy.
time is the rate at which matter moves.
matter can move at different rates.
depending on the magnetism going around/through the matter.
there for, time is magnetism interacting with matter.
magnetism can be slowed down, by the electrical resistance in matter.
there for, matter has the ability to slow down the rate at which magnetism and matter interact.
AKA slowing down "time".
magnetism REALLY has the ability, to slow down other magnetism.
there for magnetism REALLY has the ability, to slow down time.
there is magnetism in every square inch of the universe.
AT ALL TIMES.
there for the potential for magnetism flowing around/through magnetism, exists everywhere in the universe.
"electrical resistance" can slow down "time".
all mass has "electrical resistance".
though some atoms have more than other atoms.
time is slowed down, when it passes through mass.
but ONLY the time that passes through the mass, is slowed down.
the time that flowed AROUND the mass, is not slowed down.
i have noticed that electrical resistance GREATLY increases,
between 2 polarized/electrified objects.
if you placed a copper wire and a steel wire into a cup of water,
then connected a positive multimeter lead to the copper, and the negative lead to the steel,
then set the multimeter to measure the electrical resistance,
than the electrical resistance will likely read in the mega ohms !
that is right.
the mega ohms.
from copper and steel, sitting in water......
does time also slow down, if time passes through the copper, steel, and water ?
does time slow down slightly, if it passes through a capacitor which is holding a strong charge ???
onthecuttingedge2005
your Biological Mind Clock involuntarily uses the Schumann resonance of 7.3Hz as a beat frequency.
