frequency is shaped like a figure 8. NOT like a sinoid wave.
Started by nitinnun, December 07, 2009, 09:52:42 PM
nitinnun
a sinoid wave just happens to fit into a figure 8.
and just happens to be easier for a linear minded person to understand.
on top of that, this figure 8 readily folds in half !
to perfectly fit inside a circle !
and the higher the frequency, the smaller this circle becomes !
frequency readily moves, inside a round shaped object.
such as a tube shaped object.
or a cone shaped object.
or a sphere shaped object.
frequency does NOT readily flow, through a straight line.
or through any object with edges.
an object with edges,
such as a square aluminum plate,
will lower the capacity for frequency.
where a round object,
will greatly increase the capacity for frequency.
positive magnetism is one half of frequency,
and negative magnetism is the other half of frequency.
because positive magnetism spins clockwise (one half of the figure 8),
and negative magnetism spins counter-clockwise (the other half of the figure 8).
most of you likely believe that frequency is magnetism, that moves in the shape of a sinoid wave.
if so, than most of you also believe in positive and negative magnetism !
because the top half of the sinoid wave is a counter-clockwise spin,
and the bottom half of the sinoid wave is a clockwise spin !
it is impossible to have a sinoid wave, a figure 8, or the figure 8 folded in half,
without clockwise, and counter-clockwise spin !
a frequency wave would PERFECTLY fit into the 2 counter-spinning wheels, of a wimhurst machine.
because the frequency would exist in one wheel on the clockwise half of its spin,
and induct through the air into the other wheel, on the counter-clockwise half of its spin.
frequencies compatibility with the 2 counter spinning wheels of the wimhurst machine,
may be a large reason, for why the wimhurst machine generates electricity.
on top of that, electricity is made of moving electrons.
electrons only spin counter-clockwise.
which means that electrons and electrons, move in the same direction, as one half of frequency.
which means there is a link between frequency, and electricity.
which is something that many overunity torroid researchers, can likely agree with.
electrons are one half of frequency.
protons are the other half of the frequency.
neutrons are a proton shoved into an electron.
which means that every atom in existence, has BOTH halves of frequency.
which means that every atom in existence, is CAPABLE of generating frequency.
and likely DOES generate frequency, because it is already creating both halves of frequency !
a bismuth atom has 83 protons.
which means it also has about 83 neutrons, and 83 electrons.
a neutron is a proton shoved into an electron.
which means that 83 neutron actually counts as 83 protons + 83 electrons.
which means that one bismuth atom, has 332 sources of spin in it !
how high a frequency, could randomly be created, by 332 sources of spin ?
up to 162 hertz, if the clockwise spin is one half, and the counter-clockwise spin is the other half.
when you combine one frequency with another frequency,
you get a higher frequency than either frequency.
because frequency is similar to disruption.
and when you combine disruption with disruption, you get even more disruption.
so if you placed 12 different kinds of atoms in a bowl of water (that conducts their frequency),
you would get a higher frequency from all of them, than you would get from any one of them alone.
stevensrd1
