7.8 Hertz Resonant Circuit
Started by braden, December 09, 2009, 11:41:47 AM
0 Members and 18 Guests are viewing this topic.
I sure can. Or rather, to vary the frequency at which it occurs.
What you are trying to test is whether the mechanical resonance occurs at 7.8 Hz due to the influence of the Schumann resonance, or only due to the drive of the FG and the mechanical parameters of the external magnets. If the latter, changing one of those parameters should change the mechanical resonant frequency. If the former, it's hard to see why making that same change would have any effect.
So set up exactly as before, and use some modelling clay to increase the moving mass of the two vertical magnets. Then use the FG to drive the coil as before. Do you still see the strong resonance at 7.8 Hz, or at some other frequency? If at some other frequency, is it higher or lower than before?
tim123
Well, I've just been re-reading Tesla's patents on wireless energy transmission... His understanding of geophysics was pretty awesome...
His transmitter was designed to operate at a harmonic of the earth's natural frequency, and it seems he found the resonances at about 6 and 12 Hz. That would make a lot more sense - because it can include the ionosphere...
I could detect no significant 8Hz signal with my antenna experiments. So it's hard to imagine how it might affect the spin of little magnets...
tim123
Talking about Tesla, secret patents, and HAARP... I think it's possible he invented the 'ionospheric heater' in order to make it oscillate...
It would mean that we were inside a capacitor - where the plates were moving back & forth with a fixed period...
If Tesla could have made the ionosphere oscillate with a given period, it would then be possible to build tuned capacitive 'energy sucking' antennas - anywhere on earth - to draw power directly from the ionosphere.
Now that really would be *free energy*
I assume that the ionosphere would have various natural modes of oscillation, and it would probably be quite easy to pick one, and set it off.
synchro1
Tesla's system was designed to draw power from the ground not the atmosphere.
tim123
Quote from: synchro1 on January 20, 2014, 01:57:40 PM
It depends which system you're talking about.
His 'magnifying transmitter' used a ground to air circuit, and power could be taken off by 2 plates just in the ground.
The system I was referring to is different.
