7.8 Hertz Resonant Circuit
Started by braden, December 09, 2009, 11:41:47 AM
stivep
Quote from: AlienGrey on March 01, 2019, 07:05:11 AM
The schematics Wesley has republished recently on his thread look interesting but are so blurred I can't work on them to translate
and we would need more information on the wound coil data or photo to be of help, how about some more focus on that section?
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg532030/#msg532030
Now you have it
Everything including winding instructions is there.
here is set of HQ schematics that will oversize the page
one additional schematic  in good quality  is located  (2  posts above  post from link  on Wesley's forum.)
only one  schematic was not translated.
total 6 schematics
Ask these few  controversial  Russians for help.
You will see who  is who immediately
Wesley
SolarLab
As a supplement to just throwing cartoons up on the threads;
try these approaches as well:
MicroCAP Circuit Simulator: [evaluation version available at no cost]
https://www.youtube.com/results?search_query=micro-cap+12
http://www.spectrum-soft.com/demodownnew.shtm
Enter the schematic into MicroCAP, evaluate it; then publish the findings and
results - quite sure it would be very useful to varify, at least to some extent,
the blind schematics and cartoons before spreading.
Also Required: [evaluation versions are available at no cost]
Since some of the components (grenade coil and TV yoke torriod transformer,
for example) need parameters that are not common (yet) we have to perform a
full ElectroMagnetic (EM) simulation using other, more suited, analysis software
(Comsol, CST, Ansys, etc. in conjunction with bench analysis. Once the parameters
are found they can then be imported over to the circuit simulator and a complete
simulation of the device can be accurately completed.
Physical Test Set: [most already have the needed T&M instruments]
Parallel to the simulations and parameter determinations, a "test setup"
(Test Set V1 or V2) is used to physically varify component parameters and
characteristics on the bench. Test Sets V1 and V2 along with the application notes
is available elsewhere and is currently being evaluated and Alpha tested by a select
number of Maker groups.
You may even be amazed at how quickly you will understand the system's
operation and it's underlying analysis. At worst you can quickly determine
a cartoons mistakes and flaws before waisting too much time and money on
attempting a repliation.
Good luck and keep up the great work!
Void
Supposedly, the following is a newspaper story about C. Earl Ammann and his 'atmospheric generator' powered car:
Denver Post - Monday, August 8, 1921
Denver Man Invents Generator That Takes Electricity From Air & Propels Automobile
Believes He has Apparatus that will Revolutionize Power & Lighting & Gives it a Test on Streets of City
Has an invention been made that will revolutionize the electrical world? Will the apparatus conceived by
a Denver man light buildings, run automobiles, battleships, power plants by the unlimited supply of electricity
in the air? Denver electrical experts say "yes", and the young inventor, C. Earl Ammann, Monday demonstrated his
invention by attaching it to an old automobile and running it about the city.
An atmospheric generator is the name of Ammann's apparatus. It is a compact, cylindrical object with two small
brass spheres protruding from the top. Inside, Ammann says, is an arrangement of steel wires and minerals,
so fixed as to draw the electricity from the air, condense it and utilize it for driving power.
The automobile which Ammann used for his demonstration Monday was the body and chassis of an electric vehicle.
There are said to be no batteries in the car. It propelled itself with remarkable speed at the touch of the foot,
climbed hills and glided through a maze of traffic under easy control.
Careful To Conceal His Invention ~
When asked by skeptical persons if he had a storage battery concealed inside of the power cylinder, Ammann said:
"As badly as I would like to show the inside of my invention, I can't, for I have not yet obtained the patent rights.
It would be exposing the result of seven years of work to open the cylinder. I leave for Washington this week to obtain
the patent rights. When I return I will gladly show everything and I can only say, wait until then and time will tell.
"I have bucked every law of the textbooks to perfect the invention. It appears on the order of the wireless telephone but
it is decidedly different, except that the electricity is derived from the air. It will run anywhere except under water.
The automobile is only a simple test. The generator will light buildings, do away with steam turbines, and, in fact,
propel any kind of engine motor".
J. N. Davis, the proprietor of the Davis Electric Garage company, at 921 East 14th Avenue, and one of the oldest
electrical men in Denver, made a thorough study of the generator.
Electrical Man Has Faith In It ~
"I believe that Mr. Ammann has at least made the invention which will revolutionize power", Mr. Davis said. "Of course,
we don't know what is inside of the generator and the inventor would be foolish to show us. We have long known that
certain minerals exist, which if properly arranged together, would furnish power. That, in substance, according to the
blueprints of the invention, is the basis of the whole thing.
"If the generator has been perfected to the extent that it will propel an automobile, the rest of its work is assured.
It will be the greatest invention of the age. The electricity obtained from the air, first passing through the
generator, would be available for any use". So impressed was Mr. Davis that he offered the use of his building for
Mr. Ammann's headquarters. Ammann, who is but 28 years old, came to Denver from Spokane, Washington.
He is an electrical engineer and lives at the Argonaut Hotel.
P.S.  I did a search in Google Patents for any patent applications by anyone with the name Ammann
between 1920 to 1930 and couldn't find any patent applications that seem to be by those two
Ammann brothers. If they ever did apply for a patent for their 'atmospheric generator', I couldn't find
it in my Google Patent search for between 1920 and 1930. If anyone finds a patent application by these
two brothers, let us know.
stivep
SolarLab
