Thanks to ALL for your help!!
Oil turns into life
Started by brian334, December 10, 2009, 04:23:13 PM
mr_bojangles
yes i believe that is what they are saying, it doesnt turn into oil until after it was buried and pressure and heat are applied
"If at first you don't succeed, try, try again. Then quit. There's no point in being a damn fool about it."
-WC Fields
mapsrg
I like the nonfossil origin of oil which fits with the facts better than the main stream theories of buried dinosaurs Etc. This theory also means hydrocarbons are continuously created and so peak oil is a myth.
brian334
If the earth makes oil that means the chemical composition and density of the earth changes constantly.
If the density of the earth is changing because people are using oil what will that do to the orbit of the earth around the sun?
A little change in the earths orbit around the sun will cause big changes in your life.
You will either become toast or ice cream.
Judges
I spent a very large part of my life drilling oil wells.
When drilling into a formation containing oil/gas,the resulting
release of the pressure below,by intrusion of the drill string,
can produce a blow out that can quite well compare to a tornado or a hurricane. I know this to be true,been there,done that.
Mother nature is strong beyond belief.
Joe in Texas
Azorus
@ brian
The earths density doesn't change until mass is taken away from earth.  Do you think because you are walking around on earth you are taking away it's density?  Seriously give me a break what are you 8?  Thinking that because we drill oil up it changes the density of earth...
So the only time earth's density changes is when an object lifted off of earth ie. satellites, spaceships.  Other than that earths density remains relatively unchanged.
