Empirical equations predicting Newman Motor performance
Started by kmarinas86, December 14, 2009, 02:33:54 AM
kmarinas86
On my YouTube channel page, I have long ago renamed the videos so that the data appear in the titles:
http://www.youtube.com/user/kmarinas86
I have made comparisons between several of the motors. Specifically, I looked at six videos meant to achieve the following:
1) To compare the change in performance between one and two coils.
2) To compare the change in performance between two and three coils.
3) To compare the change in performance between three and four coils.
From this I deduced that when minimal other modifications are done:
For each coil added (4000 ft of 28 AWG wire):
For a given voltage, the RPM drops to 90% of the original value.
For a given voltage, The Current / Volt drops to 50% of the original value.
For a given voltage, the power output drops by (90%)^3 or 72.9% of the original value.
From there, I have developed an empirical method to predict what will happen once I get around to adding more coils:
n= newly added coils (past the current 4 coils)
v= voltage increase multiplier (1, or 100%, means the same voltage)
Note that for conventional technology, (n+4) at this power level is VERY small. It seems, however, that the value of (n+4) is only valid so as long as the wire gauge is the same. It may turn out that there is much more to it than just the number of coils when we change the gauge of the wire. Remember that empirical formulas are only estimates of what is going on. There is not much understanding right now as to the emergence of the relationships.
________________________
Adding a coil
(.9)^3/.5 = change in power out / change in power in
1.458 = change in power out / change in power in
Adding n coils:
[(.9)^3/.5]^n = change in power out / change in power in
1.458^n = change in power out / change in power in
Cooling effect
n*(backspike current)^2
Output Power
[(.9)^3]^n*v^3
[(.9)^n]^3*v^3
[v*(.9)^n]^3
If the machine is to operate at the same power output as before:
v^3 = [(10/9)^3]^n
v = [(10/9)^3]^(n/3)
If n=2, v=1.23
Input power:
(.5)^n*v^2
If the machine is to operate at the same power input as before:
v^2 = 2^n
v = 2^(n/2)
If n=2, v=2
Efficiency:
[2*(.9)^3]^n*v
[1.458]^n*v
If the machine is to operate at the same efficiency as before:
v = [1/1.458]^n
If n=2, v=0.4704
Cooling effect / Output power
[n*(backspike current)^2] / [[(.9)^3]^n*v^3]
[n/[(.9)^3]^n]]*[(backspike current)^2/v^3]
[n/[(.9)^3n]]*[(backspike current)^2/v^3]
[n/[(10/9)^(-1)^3n]]*[(backspike current)^2/v^3]
[n/[(10/9)^(-3n)]]*[(backspike current)^2/v^3]
[n*[(10/9)^3n]]*[(backspike current)^2/v^3]
For large n, n*[(10/9)^3n] rises faster than v^3 even if n is proportional to v.
Input current density (without cooling effect) (wire gauge unchanged):
(.5)^n*v
Restore to original input current density (awg rating unchanged):
2^n = v
If n=2, v=4
Output power density:
[(.9)^3]^n*v^3 / [n+4]
4 = original coil number
Output power density / Input current density ::
[[(.9)^3]^n*v^3 / [n+4]]/[(.5)^n*v]
[[2*(.9)^3]^n*v^2] / [n+4]
[1.458]^n*v^2 / [n+4]
If input current density is kept the same, the following would be the projected power density of the device:
[1.458]^n*[2^n]^2 / [n+4]
[1.458]^n*[2^(2n)] / [n+4]
[1.458]^n*[4^n] / [n+4]
[5.832]^n / [n+4]
Here it is graphed:
-3   0.0050413570150648400   0.02
-2   0.0147005970559291000   0.06
-1   0.0571559213534522000   0.23
0   0.2500000000000000000   1
1   1.1664000000000000000   4.67
2   5.6687040000000000000   22.67
1st column = n
2nd column = [5.832]^n / [n+4]
3rd column = 2nd column "normalized" (n=0)
rows 1 to 6: from 1 coil to 6 coils
jadaro2600
I don't know Stefan hasn't enabled the LaTeX plugin for SMF..  there are, after all, maths being used here. :)
See if you can get flow to do something like this:
Yay ascii art! ...  this translates, in my periodic mind, to voltage flowing backwards over current!  Think about clouds!
Meanwhile, I'm going to try to square the circle.
guruji
Hi guys I am building a Newman Motor and need a little help regarding the rotor. I am doing a circular round wood rotor and want to install eight magnets on it. What polarity should the magnets be on the rotor four N and four S?
Any help please?
kmarinas86
Quote from: guruji on December 19, 2009, 01:56:04 PM
Any help please?
Make a giant magnet out of those eight you got.
guruji
Quote from: kmarinas86 on December 19, 2009, 05:41:55 PM
Hi Kmarina thanks for response. Do you mean I should do four on one side and four on the other side?
Can I place them evenly on a round rotor with space between NNNN SSSS or it does not work that way?
