magnetic generator motors
Started by avatar, March 14, 2006, 09:12:18 PM
avatar
apparently I am not brainy enough to use this site. ?Wanted to know if anyone thought of taking a conventional radial aircraft engine with a complete electrical system and replacing the pistons and cylinder heads with magnets. ?If the theory seems to work, make a block and cylinders specifically for this app. out of say ceramics, making the cylinders and pistons a long shallow rectangular shape for ease of shaping magnets and also to enlarge them for more power....... is anyone following the basic idea here?
rakarskiy
A bit about the magnetic induction module for the engine. Rotor means cores. The number of modules required to provide relay switching is not critical. The diameter of the rotor does not matter.
https://www.youtube.com/watch?v=oTznsdT1u4g&t=28s
dieter
Avatar, magnet piston? Not getting it. You really have to explain that some more. You wanna wrap a coil around the cylinder and run this with gas?
Rakarskiy, interesting, but wouldn't the lightbulb shorten the coil?
Floor
@ Avatar
Some of the very frist electric motors were linear to crank designs.
https://www.youtube.com/watch?v=inlpMOekdms
  regards
     floor
rakarskiy
Quote from: dieter on April 01, 2017, 07:20:29 PM
In animation, only the principle. At rest, the magnetic flux is blocked. If necessary, pull out the core of the rotor, turn on the coils and break the flow. The flow of electromagnets and a permanent magnet is folded and attracted to the core of the rotor. After disconnecting the coils, the magnetic flux closes inside the magnetic circuit. Releases the rotor core. Simultaneously, it induces EMF in a magnetic field. This is the first project. To work fully, you need a special frame and control circuit.
Лампочка - просто изображение
