Free energy forest for food production - Veljko Milkovic
Started by Solomon111, December 16, 2009, 01:16:57 PM
Solomon111
The suggestion is to go back to the previous kind of nutrition - both for humans and domestic animals. The diet would include fruits of seasonal trees  (chestnut tree, walnut tree, hazel tree, almond tree, apricot tree, oak tree...), along with other trees seeking little attention, but giving healthy fruits. This procedure would restore forest that were brought down.
Trees with edible fruits could be planted on location unapproachable for agricultural mechanisation (river banks, lakes, hillsides with rocky ground, city parks etc.) Since fields have more crops when they are next to the forests, trees should be planted around fields to prevent erosion. Chestnut tree has 200kg of fruit per trunk per year, and it can live up to 500 years. Walnut tree, during its life time gives 4000 kg of fruits - with 1200 kg of fat and 200 kg of proteins, which except hazel and oak tree, can not be matched by any plant.
Intensive food production
Area between fertile trees provides ideal space for planting vegetables in greenhouses with reflecting surfaces (glossy foil or coating) helping faster grow and maturing. Garden bed can be elevated with the use of an appropriate surface.
http://www.veljkomilkovic.com/sume_za_proizvodnjuEng.html
Solomon111
Picture 1. Greenhouse with reflecting surfaces positioned between trees, from mid-autumn to mid-spring, enabling intensive vegetable production: 1- reflecting foil, 2 direct radiation of the Sun, 3- reflected radiation, 4- reflecting surface decreases emission of heat and light from the greenhouse, 5- elevated garden bed with a surface
Solomon111
GREENHOUSES AND POLYTHENE GREENHOUSES WITH REFLECTING SURFACES
Reflecting surfaces (glossy foils and coats on hard surfaces) are the cheapest energy sources. In addition to radiation of heat, they also reflect light.
For the better growth of the plant, to the green house or polythene green house can be added reflecting surfaces, like in Picture 1. The same principle can be used for growing mushrooms, desalination of sea water or distillation of polluted water.
Picture 1. Greenhouse with reflecting surfaces in winter and summer period. A- direct radiation of the Sun, B- reflected radiation. C- double reflection, 1- base for the plants of the swimming pool with salt water, 2- collecting channels for condensation, 3- lower reflecting surface, 4- upper reflecting surface, 5- glass or plastic surfaces.
Cross section of the greenhouse with reflecting surfaces. D- direct and reflected radiation of the Sun before noon, F- direct and reflecting radiation of the Sun in the afternoon, 5- transparent surfaces (glass, plastic), 3- reflecting surface.
Thermal effect is achieved through less dissipation of heat from the north side because of the placed reflecting surfaces. Insulation is also doubled in the cheapest possible way.
jadaro2600
I always have liked the greenhouses.  Most of those self built pvc styles are against building code ( of course they want you to spend money..permit, and all ).
nitinnun
most plants are edible.
though some will cause an upset stomach, if you eat too much at one time.
due to the chemicals in them.
your body can extract carbohydrates from the flowers and leaves.
so at least some of the plant is benefiting you.
for most of mankinds history, it was ordinary leaves and flowers, that mankind ate.
meat was a rarer food.
that was more for flavor.
and of course, none of it was cooked.
cooking damages the chemical structure of the food.
and this damages structure is added to the bodies tissue.
damaging the bodies tissue.
a person who eats only uncooked food,
could expect to live decades longer,
than a person who eats cooked food.
