Free energy forest for food production - Veljko Milkovic
Started by Solomon111, December 16, 2009, 01:16:57 PM
MasterPlaster
Quote from: Solomon111 on December 25, 2009, 08:30:21 AM
In his book, Veljko Milkovic said: walnut tree gives gor life around 4000kg of fruit. Of which we can gets: fat 1200kg, 200kg proteins. Besides fruits also can be used and the land under the branches of most trees. The space below it provides and intensive vegetable production in greenhouses. For greater efficiency, on greenhouses are added flare reflective surface (aluminum foil, etc.) that enables rapid growth of plants
For this method of food production can be used and city parks, the rivers, islands, rocky and hilly terrain, ineligible for agricultural machinery.
In What book?
jadaro2600
I heard if from a farmer one time, that one half acre of potatoes is enough to feed a family of four for one year.  I just can't see storing them for that long.
Quote from: MasterPlaster on December 25, 2009, 02:28:44 PM
In What book?
Indeed, this would be nice to know.
gyulasun
Hi Folks,
The books of Veljko Milkovic are here, at his site:
http://www.veljkomilkovic.com/KnjigeEng.html
"Forest for food production" and if you write an e-mail to him, you may reserve an English language copy, soon to be issued.  (milkovic@neobee.net)
Gyula
Red
For potatoes you could use solar powered heat pumps to transfer cold to the potatoes in summer and continue to grow them while using the heat to grow corn for a longer season.
Solomon111
FACILITY FOR PURIFICATION (DISTILLATION) AND DESALINATION OF SALT WATER AND POLLUTED WATER
THUNDER ENERGY
Areas where electric discharge from the clouds is frequent can be suitable for using the huge energy of a thunder. The principle is based on water heating caused by the resistance of electricity flow, similar to "express-tea pot".
Thunder energy could be used for heating salt or polluted water for distillation (Picture 1.). Electrical discharge caused by thunder lasts for 0.1 seconds with the energy of 1017 ergs, and the thunder is caused by the sudden expansion of the air heated on the temperature of 30,000° C.
During the day, the Sun is heating up the hall (4) and is producing vapour. During the night, when the temperatures are lower, the vapour is condensing, and drops gather in the collection channels (5).
In addition to distillation, similar procedure can be used for utilisation of vapour heat energy for power plants. Thunder energy would transfer to water elevation in impounded lakes through warmed vapour. Principle of a mammoth pump is a simple solution for direct use of water vapour. The use of steam turbines is also a possibility.
Picture 1. Using thunder energy to get clear water: (1) - earthen electrode, (2) - isolated pool with water for distillation, (3) - an electrode with a lightning rod, (4) - water vapour is condensing on the walls of the object and streaming down the channel (5) with distilled water and the safety valve (6) is limiting the pressure in the facility.
