POWER PLANT
Started by Hypercom, December 20, 2009, 09:24:06 AM
Hypercom
A greeting to all
The principle of the lever in the production of electric power.
Watch to see whether a special mechanical configuration, and a particular geometry of the circuit, may break some laws of physics and lead all'overunity system.
In this project we want to demonstrate overunity device which uses the principle of the lever, without resorting to esoteric phenomena ZPE or whatever.
This is an engine coupled to a generator or alternator through a config particular mechanism, this allows you to win the counterforce with an engine power reduced.
The PWM motor drive, the energy stored in the flywheel released during load variations, bring the system to 'overunity.
Alternator and engine are on the same axis of rotation (fulcrum).
The thrust engine is at a distance R1, (longer distance) from the axis of rotation (radius of thrust).
The alternator-load will produce a resistant force to the drive motor, this counterforce is RX distance (shortest distance) from the axis of rotation (radius of resistance).
Let us assume that RX is 1 / 5 of R1, through the principle of leverage can I get an output from the alternator output power greater than the electrical input power of the engine.
The energy gain remains very high even after calculating returns.
http://v3.espacenet.com/publicationDetails/biblio?DB=EPODOC&adjacent=true&locale=en_EP&FT=D&date=20021031&CC=US&NR=2002158536A1&KC=A1
Hypercom
Hypercom
Ciao
FE (free-energy) systems have existed for more than a century ...
This is demonstrated by a number of projects secured, another problem related to their free diffusion.
A FE device is comparable to the holy Grail, generates
unlimited energy and a liberal state not allow
surely, to a private company, to hold all this power
economic and social development. In a system like ours, a free energy device immediately be acquired by 'energy authorities and, if anything, in peaceful times, used to provide energy at affordable costs, see INKOMP ...
This is the situation today, but might change if, in the near future, we are heading for "Smart Grid" and the "Virtual Power Plant", the FE (free energy) equipment could be accommodated in the midst of renewable energy through a system of distributed generation, thanks to two-way connection in which the flow of energy can go in both directions ...
Hypercom
Lever of the second class: the resistant force is between fulcrum and
applied force (or power) are always advantageous.
Hypercom
Ciao
Further evidence that the leverage effect in the production of electric power brings the system all'overunity.
WO2005064777
THE PROCESS OF ELECTRIC RE-GENERATION
Abstract of WO 2005064777  (A1)
The Process of re-generating electricity by rotating the shaft of an electric generator coupled to a flywheel with permanent magnets attached and rotated by magnetic force from a smaller driver flywheel with magnets attached and placed close to the driven flywheel and in turn rotated by a smaller force. This method produces a surplus energy due to the action of leverage and Inertia, which' ensures the rotation of a heavy flywheel with relatively little effort. The magnetic power in permanent magnetic poles offers a lasting source of internal energy. The simplest method of rotation described in the invention produces a natural synchronization effect for stable rotation. The surplus energy produced or gained is used to charge continuously, an internal storage battery, which in turn supplies electric power to sustain the process. The rest is available for external use directly or through conversion process.
http://v3.espacenet.com/publicationDetails/biblio?DB=EPODOC&adjacent=true&locale=en_EP&FT=D&date=20050714&CC=WO&NR=2005064777A1&KC=A1
Hypercom
Hypercom
Ciao
In the projects secured are many concrete answers to the problem of energy, clean energy, often ignored and dismissed too quickly with the words "not relevant" ... I disagree, allow me to disagree and to invite you and those who want to do a bit of clarity to work towards the right information.
To dismiss the argument in this way means closing one's eyes to the obvious opportunity to do some clarity on that part of physics remained closed in the drawers, it may be successful by any chance? ...
What better opportunity to choose the most interesting projects and submit them for evaluation and assessment of many experts ...
Hypercom
ramset
HMMMM
Hype, have you seen one of these work??
Doesn't seem possible.
Chet
Thanks Grandma
