Request - A simple circuit to recycle flyback in a pulse motor.
Started by interestedinou, December 22, 2009, 06:22:47 AM
interestedinou
Is there anyone here who could post a simple circuit that can collect/recycle flyback current in a pulse motor and put it back into the battery that's powering the pulse motor?
I would appreciate any help anyone can provide.
For example, lets say that a battery is connected to a wire which then goes to a reed switch which closes the circuit and powers an electromagnet and the wire goes back to the opposite terminal.
What is the simplest way to put the flyback current back into the battery?
nievesoliveras
@intrestedinou
I have been working on that for a long time and had have short successes but that is a very elusive spirit.
http://www.overunity.com/index.php?topic=6362.msg158931#msg158931
Jesus
Paul-R
Quote from: interestedinou on December 22, 2009, 06:22:47 AM
The back emf from the collapsing field? I think the Bedini SG or SSG basically does
this, as do certain implementations of the Robert Adams device.
jadaro2600
I concur with both posters' previous topics.  The flyback idea is sound, but I don't think the power going in can flyback with as much force as it flies in unless precisely timed.
The Bedini device is supposed to use the momentum of a magnetic flywheel to re-send the pulse backward, as a magnetic field collapses, it does so in a direction reverse of the current put in.  As a pole of a magnet nears a solenoid, the ( a ) magnetic field is setup in such a way as to oppose this incoming field.  The two are supposed to work together.
They may in fact, and a flywheel would be a convenient way to create resonance which varies according to pulse characteristics, it will act like a pulse motor ( synchronous ).
gyulasun
Hi.
Here are two circuits, try to adopt to your needs, your pulse motor can be connected in the place of the coil, as THE inductance.
http://www.overunity.com/index.php?topic=5446.0
http://www.energeticforum.com/renewable-energy/4314-cop-17-heater-rosemary-ainslie.html#post56075
In the second link your motor can be connected to replace the RL resistor AND REMOVE diode D1 and place a short piece of wire to connect the circuit to battery negative. i.e. omit the D1 and short circuit its place.
The problem with pulse motors is that the coils if they have iron cores, change their inductance when the rotor passes them (approach, face then leave) so the collectable flyback pulse energy varies from 40-85% wrt the input energy. If the design of the motor is such that this inductance change is very little or there is not at all, then recovery may go above 90%.  (very rare)
rgds, Gyula
