Self-Running Bedini Bike!
Started by Elliot Gain, December 24, 2009, 10:11:28 AM
Elliot Gain
..at least thats the idea.  Ok so I am new to all of this, but I have started to assemble a bedini circuit, haven't got it running yet however...
I want to attach the bedini circuit to my electric bike and charge a battery as I ride, using the wheel as the rotor, I will attach magnets to the wheel, place an EM coil on the frame so the magnets pass by it, and then capture that energy in the bedini circuit fashion, flyback voltage or whatever.
However I dont think I will even need the seed energy since that will be provided by the electric motor/me pedaling, so can I just leave the power battery out of the circuit?  If thats the case do I even need a trigger/power bifilar coil or can I simply use a single wire coil?
The electric bike has a spot for two batteries and runs off 24V SLA.  It also has a handy switch to go between two batteries.  I figure I can use one to run the bike, and charge the other.  What do you all think of this idea?  I could even add coils to get it more efficient yes?  I mean with the bike I have two rotors (wheels) spinning all the time with all that energy not being tapped at all.  Whats the best way for me to tap this energy?  Your thoughts are appreciated.
Low-Q
If you can, you place several coils on it. Maybe it works better than only two?
Using the wheel as the rotor will reduce loss compared to using transmissions etc - good idea!
Vidar
Elliot Gain
If anyone is familiar with the bedini circuit or electronics and could let me know what I would need to get this going?  If I could just use the standard circuit or if I should modify it since I dont need the seed power?!?!  Your input is appreciated.
Low-Q
mr_bojangles
welllllll, it wouldn't run itself
you would be giving a force equivalent to the weight of the bike, friction of the wheels, and time (how fast)
each time you add something to this (your body weight, going faster, uphill, over rocks, dirty wheel axles), it takes more and more energy input to keep the bike going
the thing with generators is that the faster you spin them, the more energy it takes to keep it spinning
this would feel like gradually biking onto sand, it takes more energy to go the same distance, like a generator
you would need a decent sized motor to power a bike, which is why most electric bikes are "hybrid" human power and electric
as Low-Q said, you do have an interesting new approach, but it wouldn't nearly run itself
the benefit of your system would be in regenerative breaking, and going downhill
that would be zero input, a decent amount of output
uphill would have the opposite affect, and flat surface would not do much
another benefit of your system would be the distance of the magnet from the axle, which is big, meaning a faster speed with the same amount of angular rotation
i think it would be a bit difficult to fix the magnets onto the wheel itself and keep them there, but that might be the least of your worries
start out with a stationary bike, or just build a little stand to lift off your back tire, and see what you can do with it
"If at first you don't succeed, try, try again. Then quit. There's no point in being a damn fool about it."
-WC Fields
