New Jewel Thief "Resonate LCR Circuit" Much less energy draw....
Started by sirmikey1, January 01, 2010, 09:25:10 AM
david7630274
Here's  an idea you may want to consider. If you can get your hands on a transformer 110v to 9v, connect the output to the pri (9V) side and see if you can step up the voltage and light up a neon bulb. If you set it up right you will get a mild shock on the secondary(110v) side.  :o
David7630274
xee2
sirmikey1
   Jeanna has added many secondaries, useful for lighting every room of the house using one Joule Thief.
Her Schematic Attached
SM
sirmikey1
xee2,
2n4401 NPN EBC General Purpose
2n4403 PNP EBC
  I can also run to radio shack if needed...
Thanks,
SM
xee2
I did a quick test of circuit. It will light neon and it looks like it may be putting out AC (I can not really tell since I do not have a scope).
EDIT: I used an ignition coil, but I think it will work with the xenon trigger coils also. The small ignition coil I used had a primary resistance of 0.7 ohms, a coil with higher primary resistance may not work as well.
