New Jewel Thief "Resonate LCR Circuit" Much less energy draw....
Started by sirmikey1, January 01, 2010, 09:25:10 AM
crowclaw
Quote from: david7630274 on January 03, 2010, 02:06:12 PM
Here's  an idea you may want to consider. If you can get your hands on a transformer 110v to 9v, connect the output to the pri (9V) side and see if you can step up the voltage and light up a neon bulb. If you set it up right you will get a mild shock on the secondary(110v) side.  :o
David7630274
Hi David,
This transformer idea is OK for low frequencies, you transformer is designed to operate at 60 Hz hence the laminated metal core.  JT's etc are high frequency oscillators, the core materials are ferrite.
stprue
Quote from: sirmikey1 on January 04, 2010, 11:33:03 AM
xee2,
EDIT: chilliqueen circuit is no joule thief.  Stopped around 5am today, and the Joule thief is on the same battery  and still going, . Still going fairly strong.  Chilliqueen is obviouly not pumping kicking out the Joules
  Jeanna's getting 170volts from her little torroid.  Lid says he's pumping that A/C into a rectifier, and then puts it across a spark gap to pulse an ignition coil;;; and this is creating monster sparks.  Thick Spikey thorny sparks.
   The heavy sparks are probably good for the big stuff; motors and heating.
   Reminds me of Steven Mark videos, he was inserting a little button cell battery to kick it off ???
Mike East
Like GK said, monster sparks are probably from a stun gun circuit!
sirmikey1
Quote from: stprue on January 04, 2010, 04:18:00 PMLike GK said, monster sparks are probably from a stun gun circuit!
  This has all been one heck of a show, so far.  Looked at some stun-gun circuits...  yea exactly that's what Lid is doing with the Lightning Maker; though he may not yet realize it.  Brings back some memories.
  What, is the stun gun soon to replace the motor/generator armature?
Mikey
kooler
mikey
you must not read ...
if you look at my schematic in the jt section ,,.. it says strobe/ stungun circuit  and if you (read) lidmotors info on his video it says '' The project was inspired by "Kooler's" ideas and Tesla coil designs '' but chances are you won't see this... since you don't (read)
i just playing with you anyway..haha
xee2
i found something really weird to me... i made the circuit you posted but with a 0.47 cap and a 55 k resistor
well no load it pulls 56.4 ma but....... with a load it shows 3.83ma  ( the load being a neon half bright 78 volts )
and it runs at 1181.3 hz
sirmikey1
Kooler,
  Hello and great to meet you. Thanks for the heads-up, the 3ma neon. Yea, didn't catch that earlier, had my head into the original here. Threshold, the original here crashes sooner, wont JT.
   I've now got the original joule thief powering the xee2 joule thief with that dead battery. Bright...
Thanks,
Mikey
