New magnet powered perpetual motion machine
Started by hartiberlin, January 01, 2010, 09:18:36 PM
mike-ao
Quote from: dradak1 on January 08, 2010, 11:44:09 AM
That mean around 6 billion humans are presently on Mother Earth.  :)
tnx, sorry the dumb question ;) ... I've misunderstood the billion..
German counts different
Quote from: neptune on January 08, 2010, 01:16:38 PMIf you have tried to replicate this machine , please share it here , even if it failed to work .
I've started to work today on it. i use some Plexiglas, so the major part's will be visible. trough the w-end I'll fool around to balance the picker-bird. *gg*
as soon i finish the replication, I'll place one or two  IP-cam's on it and I'll give you the URL for viewing wit VLC-player. i hope it will work
norman6538
I put a rapid prototype together with only the one side using a balanced see-saw instead of the gillotine because I  suspected it would be prone to sticking. I use wire stops and wire axles that can easily be repositioned in wood holes and used aluminum soffet to make C channel for the arms and see-saws and connected them with small craft wire to lift the gillotine/see-saw.
Amagingly there is action at quite a distance.
No cigar. The action
works but when the magnet drops near the pendulum it stops and does not continue down.
This is because of a magnetic phenonemon I call describe as "there is no push without a squeeze" and so we have to pay for the squeeze. This could easily be seen if a string was
used to drop the gillotine then it would not drop and extra string would be seen.
Better luck to you. I am working on Lafonte stuff at the same time. So I vacilate back and forth between them because I am addicted to magnets.
Norman
gyulasun
Quote from: norman6538 on January 09, 2010, 01:01:41 PM
Amazingly there is action at quite a distance.
No cigar. The action works but when the magnet drops near the pendulum it stops and does not continue down.
This is because of a magnetic phenonemon I call describe as "there is no push without a squeeze" and so we have to pay for the squeeze. This could easily be seen if a string was used to drop the gillotine then it would not drop and extra string would be seen.
Hi Norman,
I apologize but I did not get your explanation why the gillotine did not continue to drop fully down?
Was it because the coming pendulum magnet did not let it drop but kept it at a distance up from the full down position?
Sorry and thanks,  Gyula
ramset
Norman
Thanks for sharing
If your addicted then you must follow a master addict
http://www.overunity.com/index.php?topic=8620.0
Chet
Thanks Grandma
forest
Gravity should replace squeeze force.
In other ways this device is using repelling magnets to force pendulum UP , then gravity is net zero force and pull it DOWN.I'm wondering where is "the sticky point"
