Hairpin Project
Started by resonanceman, January 02, 2010, 09:20:03 PM
onthecuttingedge2005
the electron only has to circumvent the velocity of the nucleus which is spinning on a rotation far less than light speed in 3D axle rotation are you telling me that an electron is traveling faster than the proton on axle rotation, it does not have to be at the speed of light. field equalization is only required. since an electron is omni-spherical in field it will behave as such. pretty simple stuff! all else is highly predictable.
the only reason why an electron bubble would have any spin is because the nucleus is spinning, the nucleus is stable in its spin because it has field vectors that keep it from spinning, this is called the field of least resistant! bound Protons and electrons are subject to this law, period! their own fields will coincide with this law.
you listen to, to much classical mechanics. classical mechanics is nothing but poison to the current science age. it should of never of been invented.
resonanceman
Quote from: jeanna on January 08, 2010, 11:58:41 PM
Gary,
I am curious to know what you are doing and how you are changing the Karl Palsness replication of version um 2, I think, of the 3 possible pix?
Are you using that one?
Are you using the one that is open at all?
Karl said the horseshoe is safer, so that is my bet, but I am always curious to see how someone makes a new build interpretation.
thank you,
jeanna
Jeanna
right  now I am waiting for the books I ordered and  doing a little research .....
Right now I have 3 things
Motivation
a theory
and lots of questions
I am thinking that  the actual hairpin should be  pretty much like in ther video.......with a removable  bar on  top.....if  for no other reason than to see that it does change things when the bar is removed.
If my theory is right...... a small hairpin would let alot of radiant energy go around it rather than  through the load..........so I am thinking at least 5 ft tall
For the  rods..........ground rods are around 5 ft.........but I am pretty sure that  they are copper plated iron now ........
I have not checked yet ...............but I am thinking of using  wire usually used for  grounding stuff .........I know 1/4 inch is common.....
They might  have  some thicker ......
Copper pipe might  be an option too
With pipe I think I would  go with at least 1 inch
For  the  caps on the ends of the rods I am thinking of making my own
I read  somewhere  about  caps made with tubes ....... I might  try that .....
A PVC pipe might  make a pretty good dialectrric
A copper  pipe inside that would be one plate....... the outer plate could  be adjustable ....... it would  be fairly easy to wrap  it with  copper sheet or  aluminum  foil  for the other plate.... wrap less  of it for smaller capacitance
Or ........if  I use the ground  wire......... they make polyethylene tubes that would probably  slide  right over the  copper........it might take a couple feet to have enough capacitance.........but the  with the ground  wire as a plate  the connection on that end at least will always  be good.
The copper tape they use for making stained  glass windows might be a very good  outer plate
anyway....there is lots of  choices to make........lots of experimenting  to see what works.
gary
Quote from: resonanceman on January 09, 2010, 12:47:12 AM
Jeanna
Motivation
a theory
gary
Good luck Gary, I know how lazy energy can be! very lazy! it will not do work for you unless you crack the whip! this is the truth! let the truth be told!
Jerry 8)
jeanna
Nice overview Gary.
Thank you.
Jerry,
Maybe you need to find something you are passionate about?
I can hardly wait to get up in the morning most days.
I am so ready to try my thoughts out.
I can guarantee that if we were doing something I "should" do, it would be different!
11PM time to sleep!
nite
jeanna
sparks
       I am just saying that electrons are assigned a very specific mass quantity.  Why in the world would this mass not be convertible to energy.  Is there a limit on how much mass you need to have before you can convert it to energy.  How many photons can exist in the same place at the same time.  Lots of em.  After a while they become massive.  The cosmic background radiation does not only scatter it is effected by mass.   It condenses into mass.  Electron is probably the first ordering of the randomized oscillations.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
