Hairpin Project
Started by resonanceman, January 02, 2010, 09:20:03 PM
Magluvin
Jad
Tesla said that it went through glass, copper sheets that he tried to shield himself with. He said it passed through everything. And that is how he knew his power transmitter from 1 tower would be able to be received around the world by his power receivers.
But once he got it to pulse above a certain freq, the pulses were no longer felt.
Magluvin
Magluvin
Jad
Read  Free energy secrets of cold electricity  Peter A Lindemann  then you will know   =]
Magluvin
onthecuttingedge2005
Quote from: Loner on January 05, 2010, 11:26:32 AM
HAD to butt in again.  Quick info.  To stop the human heart only requires 75mA!   This is the value warned about in EE courses, and though I haven't "Proven" it by stopping a heart, but I have no reason to disbelieve it.
Just an old piece of data I consider important....
Hi Loner.
that is why I said 'About', here is what I said;
you have to have about 1 amp to stop the heart, there is a trade off on HV electricity, raising the voltage causes the amperage to drop, decrease the amperage and the voltage rises. for transformers.
this is not the case for Lightning which contains 'both' high voltage and high amperes. it is totally bad ass.
on average everybodies electrolytes are different, if you lack electrolytes your skin becomes less conductive, it requires more current to electrocute someone with a lack of electrolytes, this is why they sponge your head during an electrocutions.
1 amp is the standard in the electrical value as an Electrician's safety range. at least that is what I recall from the Electrical trade, might be 75mA's but it is rounded off for general safety training.
thanks for the info.
Jerry ;)
jeanna
Quote from: Loner on January 05, 2010, 01:37:11 AM
I don't mean to intrude, but a little thing that was handy in work that I did (and am doing...) was a very small spark gap with electromagnet boost on the quench field.  Most will find this hard to accept, but a neon bulb is a spark gap.  Standard bulb has two wires, that can have a mag field applied.  Forcing a field between two already formed fields causes compression, etc.  Not exactly low voltage, but lower than most "open-air" gaps.  IF you play, tuning via electromagnet strength is what I found easiest, instead of trying to find the "Right" bulb.  You know there is too much "Real" current by lighting, etc, etc, etc.
Just something I came across and thought I should mention.  Also, to avoid HV, always take the output from the Hairpin across the "Shorted" loop, after the "Isolation" caps, regardless of exact design.  Normal HV cannot exist there, so the output is always safe.
Of course, this is old data, previously posted, but I just thought I should re-mention it.  I'll shut up now...
Actually loner,
If you don't mind I would like to know more precisely to what you are referring.
1- How are you making an EM boost on the quench field.
And what is the quench field?
2- How do you force a field between two already formed fields?
3- What method are you using to measure your tuning via EM strength?
4-  please identify the "shorted" loop and the "isolation caps"
thank you,
jeanna
Magluvin
Jeanna
It was like I said before.  I know you must not have gotten into it yet, Lindemanns book tells the story and also Secrets of cold war technology. Its DC unidirectional impulse. Quenching the gap kind is kind of like a poor mans super diode. Tesla tried other ways like using air pressure to blow it out. But he ended up with the magnetic way that has the N and S poles near the gap and it strips the electrons from the stream leaving the pure radiant electical potential there. By doing this, any reversal of current in the gap is canceled. This when he really got the full effect to happen. At lower freq than 100 micro sec there were different effects like cool breezes, heightened awareness, effects that caused the whole lab to glow, burning sensations of the skin and face.. Different effects at different pulse freq. At higher freq than 100 micro sec everything was good, no stinging, now glow no breezes. and caused no harm. Now he planned to use that for transmission of power. Some stories claim that he planned on 2 towers, 1 on each end of the earth. But the real deal was just the 1 tower due to the fact that the radiant energy passed through all matter, glass, copper sheets, stone mountains and the earth itself.
You should check it out it is an awesome read. Highly recommended. He later founf that he did not need the transmitter and the radiant energy was readily available using the receivers he developed in his last days and that was what he used to power the Peirce Arrow electric car.
This is what I am very interested in. As you can imagine it would be a highly suppressed idea.
mags
