Hairpin Project
Started by resonanceman, January 02, 2010, 09:20:03 PM
resonanceman
Quote from: sparks on January 06, 2010, 07:55:17 AM
@resonanceman
     In good time.  ;)  Take a Tesla pancake coil and set it on its side.  Look at it.  What you have is a very short conductor with a huge cross section and surface area.   When the haripin coil is placed so that its magnetic field disruption intersects the superthin large diameter  and surface area conductor you get the most bang for the buck.  Positive on top of the conductor negative on the bottom.  Lots of polarization of charge.   Electrons dont have to go too far before they find themselves on a capacitor plate.  Just head towards the end of the conductor they are in already.
Sparks
I Like  the idea
I will test it as soon as I have some indication of radiant energy.
gary
resonanceman
Quote from: jadaro2600 on January 06, 2010, 11:35:54 AM
can someone please post a newer circuit diagram of the device in question
Jadaro
I am working on it.
I am working from  related knowledge , videos and theories right now.
According to the video  Jeanna posted  a drawing is on page 128 of one of the books I have on the way.
I will redraw that picture  and post it when I get it.
gary
resonanceman
I have came  up with a theory of what is  going on with the  hairpin circuit and radiant energy in general.
To start I would like to point out a recurring theme in the physical .
An  atom  has a nucleus with atoms rotating around it.
If we change  the names  we can  see the  same structure in other places
If  we call the nucleas a central mass   and  the  electrons  simply  objects orbiting  the central mass ....then our solar system looks like an atom  .......the earth and moon look a lot like a  hydrogen atom
The  galaxy is said to  have a black hole in its center .,,,,,,,if so......it too looks like  an atom...... a very complex atom  but it is still  a central mass with objects rotating  around it.
Is it not  conceivable that this  recurring  structure extends at least one level smaller than we can see?
What if  electrons  have a central mass  and  objects orbiting it?
My theory  is  that this is in fact true
The electrons of electrons are small enough to have  no measurable  mass  I believe that they are comprise what Bearden calls displacement current.
Like  the  electrons  of  the atoms  these electrons  stay put in their orbits  for the most part but  like the electrons  of atoms they also  can  be moved from  atom to atom.
Radiant energy is illusive because it is the  second order of electricity
The first order  is easy for  us to see.
The  second order comes into play  after the first order is put into play.
The  second order is usually obscured by the first order....... normal electricity
Because  this  energy  is of the second level.......current has been induced  from  the atoms  then the electrons this energy could be thought  of as hyper electricity
It would   be very  active
It would  recombine  with electrons  quickly once  the impulse  that pushed it out  of its orbits was removed.
In other words  it has to be kept moving  and  under pressure  all the time .......if it slows down ........it recombines with an atom
In practical term this means that   the hyper  electricity  is hyper  affected by  resistance  and  impedance........anything that slows it down kills the effect.
That is  why  good quality rods are needed  on the hairpin .....in fact   all the  conductors should be  large and  good quality.   The  actual secondary of  a JT  ( assuming  we get a JT to power  a hairpin ) should  be relatively heavy wire ....butr because it is where  the  hyper  electrons  are to be booted from there orbits they  should be under enough  presure to  keep going.
The  wire  between the  coil and the  isolation caps should be heavy
The  caps themselves should  be heavy .....I am thinking  of  plates of copper.
Because   the hyper electrons  have a high amplitude  and  no mass they pass through caps much more easily than normal  electricity ..... this is why  the isolation  caps  of the  hairpin  can provide it  with  an easy  path.
It looks to me like the  greatest  radiant energy  is  at  the lower parts of the rods of the  hairpin.
I believe  that  the  close you get to the rod across the  top the less power is available.......because  the radiant energy can go around  the loop easier than through the load.
One of the videos I watched  told about  the  hairpin  being able to power  a light bulb through very fine  wires....... the wired does not get hot.
I think that this is possible as long  as you have enough amplitude to keep  the hyper electrons in the hyper state   ,,,,,,,, until they start recombining  with atoms  they make no heat.
The relative resistance of the  light bulb slows them down and causes them change to normal electricity
gary
jadaro2600
Quote from: resonanceman on January 06, 2010, 01:23:43 PM
Jadaro
I am working on it.
gary
Thank you, I think the chilliqueen, jtc, etc will be a good way to power this at lower voltages, I think they can all incorporate rather well.
resonanceman
Quote from: jadaro2600 on January 06, 2010, 03:16:27 PM
Jadaro
At first I did not remember that  JT
I have not had time to try it yet.........although  I did  get  the transistrors  for it
I am going to try TIP3055  and TIP2955
in case  someone  else  does not remember
http://www.overunity.com/index.php?topic=8564.0
gary
