Agentgates´s TPU setup with strange wavehill hump
Started by agentgates, January 05, 2010, 09:28:18 AM
I tried to post this yesterday:
The LC tank on the primary idea is indeed worth a try. If the coil accelerates the electrons then each cycle the tank voltage rises instead of dampening right? This could then be fully isolated from the outside, all it would need is a starting pulse and it would run off, probably some safety measures should be taken not to over charge the high voltage capacitor.
Does this sound sane?
darkspeed
Very Interesting stuff!
Weigh your two coils I think you will find the mass needs to be equal for best results.
zerotensor
Quote from: agentgates link=topic=8586.msg220192#msg220192 =1262854152
@zerotensor
WOW! Beautiful work. May I use them later on presentations? :)
Thanks.  Sure, you can use these images however you like.  I can also provide you with customized plots -- The code I wrote to generate these graphics is fairly generalized, so given a diameter, height, offset angle, and number of turns, I can render the corresponding coil image in just about any format and size.  PM me if you want an image for a specific config.  I didn't model the thickness of the cylinder on these, but I could easily do that if need-be.
My motivation in working-out the mathematical parameterization of the wire segments was that it will be useful for modelling the magnetic field produced by the coil.
Just for kicks, I made an animation where the offset angle is varied.  Check it out:
agentgates
Hello broli,
Yes the LC sounds good to try but presently I am on that to remove as many parts I can. When I finished with those modifications that I have imagined it will be not necessary, but if the heating problem remains we will certainly address to this one. Until then I don't want to add new components to the design.
Thanks for the suggestion. :)
agentgates
@zerotensor
WOW, amazing! :) We'll get back to this subject, thanks for the help. :)
