Agentgates´s TPU setup with strange wavehill hump
Started by agentgates, January 05, 2010, 09:28:18 AM
gadgetmall
IF i may so kindly ask the inventor here a simple question . I realize there is a circuit you are or have experimented with that you say it not easy to duplicate and you are trying to make an "easier"one for us . Can you be so kind as to post the Hard circuit so i can blow up some fet s with 0.011 ma @ 35 volts ? I got plenty of parts so i can follow along with you .In the Meantime I am your competitor in the Ou race and have posted all my primary circuits and test and of coarse we are in the Final testing stages for a few months until Me and one other person are satisfied  with the results at which time Stephan will also have the opportunity to see a Video and get his Device for inspection . Surely a device of your nature can demonstrate a measly 1 watt out  to win the contest and it's nice that you are Scaling it up but really all that is needed is 1 watt continuious output with self running .
kind regards
Gadget
minde4000
@Spider
What are you driving your coil with? At least you have your bulbs lit.... I got nothing :)
@All
I guess I got nothing because I dont have a driver required  for it... no igbt handy... only mosfets and hexfets.
Lawton pulser aint suitable for this.. SG is out of the question.. any suggestions?
Thank You
M
Magluvin
Thanks Altair
An important clue and maybe fact is,  how the imagined spinning disks from the inner and outer primaries cut the secondary. Depending on what side secondary is to the primary, the secondary will see something different from 1 side to the other, especially at the angles we have laid out here. So if Stephans sample does not work because the secondary is inside, then the outside is where it should be. I hope.
I bet that some length of wire set up on a jig to allow different angle crossings and multiple primary above and below configs, all done at just 1 single cross point, some sensitive equipment could be used to determining if the effect is real and simplify angle and position that works best then put it to coil form.
I actually think it can be made like a woven screen and flat, if what we are concerned with are the crossings.
Just an idea for further analysis.
Magluvin
mflynn44
Try a neon sign transformer with a spark gap.
Quote from: minde4000 on January 07, 2010, 11:56:27 AM
@Spider
What are you driving your A with? At least you have your bulbs lit.... I got nothing :)
@All
Thank You
M
agentgates
@Everybody
3-primary-channel coils are done, secondary is coming soon after the . If it's possible avoid using clear acrylic with the 3 primary as you will get mixed up by the transparent surface and you'll see a cobweb everywhere. I had to rewind it 3 times as I screwd up.  :-\
gotoluc, broli thanks for understanding me in 100% and helping me out. Indeed I don't want anybody to patent it and sit on this wondeful piece of technology for another few decades and I also agree with Stefan the best if I start disclosing everything. Everyone in this topic is also a withness that nobody has right to take it away from the people.
As for the OU price I am not really look into win just try it if possible and wanted to make sure whether should I bring this one in priority or do my other projects. Thanks for understanding now.
REQUEST TO A KIND VOLUNTEER
4017 is in its place, 3 channel will fire after each other over and over again. My request would be somebody who has a few minutes could please make a schematic with a 4017 decade counter driving 3x BC337 calculated resistors hooked to the primary channels? The inductance is around 100uH if I read it right (fluctuating).
Until epoxy is bonding I would have a few hours nap as my brain is getting to shut down.
I'll be back soon. Many thanks in advance to All.
PS: Bruce, don't worry, no prob. just please be a little patient. THX ;)
