Agentgates´s TPU setup with strange wavehill hump
Started by agentgates, January 05, 2010, 09:28:18 AM
gadgetmall
Quote from: starcruiser on January 05, 2010, 04:09:45 PM
There is no circuit just a coil configuration and how it is wound.
Input low voltage low amps (mA) he is using 31vdc @ .09A (90mA) and getting over 1KW out
Current issue is the BEMF (or ???) to the input drivers which causes failure due to over voltage/curent. Read the thread for more on this.
ISNT 0.09v      9 100ths of an amp ? if  1.00= 1amp . and 1.10 is 1amp and 10 ma then 1.01 is one amp and 1 microamp not milli  ,correct ?
gadget
Magluvin
So the decade counter can drive the mosfets no? It mus be at supply voltage levels on those outputs.
And probably a descent dvm with hz setting isnt that expensive. And a pc scope. simple and wont break the bank for most.
Mags
ketone
@Gadgetmall
                  1 amp = 1.00
                  1/10 amp = .1
                   1/100 amp = .01
                    1 milliamp = .001
Spider
Way back I uploaded this video:
http://www.overunity.com/index.php?action=downloads;sa=downfile&id=149
Maybe I should fire that through the coil....4000V 200Watt.....but i am afraid my house will blow up LOL
I have 3 of those, so maybe in phase.. 1 2 3
Back for more
Spider
When a magnetic field, produced by a moving electric field, is moved longitudinally a tempic field is produced.
Groundloop
Tony,
Attached is my proposed 4017 circuit.
The Eagle CAD design files are attached as a compressed rar file.
(Eagle CAD can be downloaded for free at www.Cadsoft.de )
Edit: There was a small error in the PCB so I uploaded the new files.
EDIT: New changes based on recommendations from Tony.
Regards,
Alex.
