Agentgates´s TPU setup with strange wavehill hump
Started by agentgates, January 05, 2010, 09:28:18 AM
gadgetmall
Quote from: ketone on January 07, 2010, 09:55:13 PM
@gadgetmall
                 it looks like your inner primary winding is going the same way as the outer winding...when it should be the other way...you need to wind it like a triangle pattern upright,upside down,upright upside down etc...WWWWWWW....although...i wonder if
Hi .Actually it is correct winding according to his device . I just didnt put enuff slits and did it backwards and not at 45 degrees . . look here . Its straight forward . http://www.samsonium.org/sites/default/files/P1050245.JPG
Magluvin
gadget
ketone is correct. your inside winding is following the outside angles. If you had a plexi tube, there wont be any dots or lets say crossings between the inner and outer primary turns. Your inner and outer follow the same line.
Not that it is the end of the world mind you, and it is another version that may work. But it is not the same as described. and that coil with the yellow wire is said to be wrong and doesnt work according to tony.
Mags
Magluvin
Actually Gadget, Even though it is wrong, now that I think about it, HOW did you get it that way? I am in my mind trying to see the path that the thread would follow an its a physical impossibility!  Without some fangled routing, my guess by seeing it, it looks like a single loop from one hole to another. Athough I cannot see under the tape.
Im not making fun of your build, its just fact, how did you do that?   lol =]
Mags
Groundloop
Tony,
>>Alex, I've got BC337-16 and BC337-40. Are you sure in the 100mA? They don't switch in my configuration.
The BC337 is a general purpose npn transistor capable of switching up to 0,8 ampere for the /25
and /40 type, and 0,5 ampere for the other types. I set the current limiting resistor to a value
that will ensure a maximum of 100mA through the transistor. The base resistor is there so that
we do not over current the 4017 ability (10mA) to source current. I can't find any errors in my circuit.
Alex.
nightlife
  I do hope that these devises that use coils and or torrids are actually accumulating energy that is not emitted from energy supplied by humans in the surrounding area.
These devises must be tested away from any human supplied energy. That means no power wires, no houses and no machinery. I would suggest that testing be done more then a mile from any human energy source including human emitted airwaves.
  I don't want to discourage anyone but at the same time, I don't want anyone wasting time by jumping to conclusions without properly testing first.
