Agentgates´s TPU setup with strange wavehill hump
Started by agentgates, January 05, 2010, 09:28:18 AM
plengo
Using SUPER go to this page for the best conversion for Youtube.
http://webvideotechniques.com/35/how-to-encode-your-videos-for-youtubes-new-high-quality-option
Enough with the details, just give me the encoding settings!
Open SUPER and import your source video. Make sure you do not change any default settings except for the ones noted below.
Set Output Container as: MP4
Set Output Video Codec as: H.264/AVC
Set Output Audio Codec as: AAC LC
Under Video Scale Size, check the More box and enter 640 : 480 (4:3) or 640 : 360 (16:9 widescreen)
Set Aspect to 4:3 for SD or 16:9 for HD/Widescreen
Set Frames per Second to 29.97  (Note: As long as your Source is progressive, you can use virtually any frame rate 24, 25,30, etc.)
For Bitrate kbps, choose 4080
IMPORTANT: Depending on the amount of movement and color in your video, you may need to raise the bitrate.
During testing using a clip with a lot of motion, 4080 provided the best end results.
If the video you export has blocks or artifacts, then you may try raising the bitrate to 5000kbps.
Make sure “Hi Quality” selected BUT NOT “Top Quality”
Uncheck 48k Audio
Select a Sample Rate of 44100
Set the channels to 2
For Bitrate kbps, select 256
Click the encode button to encode your video
Fausto.
altair
Anthony,
a video is not really needed-
Just give us the specs with a few pics and we will be all right.
gotoluc
Quote from: agentgates on January 09, 2010, 12:51:39 PM
UPDATE2
I've converted it, no sound again and vid is choppy. >:(
What format should I use for youtube? Thanks in advance.
Hi Anthony,
God knows I have done many video's on Youtube.
I use Super like Stefan has suggested: http://download.cnet.com/3001-2194_4-10277613.html?spi=9c02d478042d76a42f60c92869355434
Capture Full DV to computer, after edit (if needed) use Super to convert for Youtube upload. Make sure video is not more than 10 minutes.
Settings for Super, "output container" select: avi, "output video codec" select: H.264/AVC, "output audio codec" select: mp3.
Video scale size select: 320 x 240, aspect: 4:3, frame/sec: 23.976, bitrate: 1008, options: check mark in Hi quality box
Audio sampling Feq: 22050, Channels: 1, Bitrate: 96
Right click where you drop video and select where you want the converted file to be saved before you start and then drop or right click to select the video to be converted.
This will make a great quality file that will be just under 100mb and very compatible with Youtube codec so not too much loss will happen when they convert it.
Hope this helps.
Luc
gotoluc
Quote from: plengo on January 09, 2010, 07:14:44 PM
Uncheck 48k Audio
Fausto.
Hi Fausto,
just noticed your post ;D
Anthony maybe in Europe so I suggested he selects 23,976 for frame rate since video in 220vac/50Hz countries are at this frame rate. Even if he is in America or Canada it will still work but it dosen't work well the other way around to increase frame rate.
Luc
Freezer
Quote from: gotoluc on January 09, 2010, 07:32:30 PM
320x240 is pretty low resolution even for youtube, I would upload at least 640x360/ 640x480.  Of course if your source is lower than that it won't even matter.
Man just send me the video, I'll have it uploaded in 2 minutes. :p
